07-23-2016, 09:22 PM | #1 |
Steering Wheel Install Issue
Not sure how to install this steering column and get the horn to work. This is a pic of my steering column and also the steer wheel with the install kit that came with it. Any help would be appreciated. Thanks.
07-24-2016, 07:38 AM | #2 |
Re: Steering Wheel Install Issue
Anyone know how to get the horn working based on the image/parts listed? Thanks
07-24-2016, 11:08 AM | #3 |
I believe u throw on the black spacer then the metal plate the the steering wheel then the horn button. Not shure with the white pin by screws maby a new contact. For the old new replacement. All your doing is trying to make path to complete a circuit. .
07-24-2016, 11:27 AM | #4 |
[QUOTE=Clavo106;7663064]I believe u throw on the black spacer then the metal plate the the steering wheel then the horn button. Not shure with the white pin by screws maby a new contact. For the old new replacement. All your doing is trying to make path to complete a circuit. .[/QUOTE
I guess im confused because I do not see a wire for the horn like I have seen in different YouTube Videos. |
07-24-2016, 11:45 AM | #5 |
Yep thats how it was on my old truck one a wire to the back of the horn button. the horn should only touch the metal when its pressed in ..to complete s the circuit...
07-24-2016, 12:57 PM | #6 |
I don't know, but is the install kit different for a tilt vs non-tilt? By the way what steering wheel is that? I have been looking for one similar.
1972 Chevy LWB Roadster 1999 Chevy Silverado 2wd 2015 Chevy High Country 4x4 Crew Cab |
07-24-2016, 01:14 PM | #7 |
