Old 07-24-2016, 08:04 AM   #1
kashimus
trailing arm vs leaf
so i bought a 64 gmc. it has the leaf springs on the rear. I really want to bag it. im looking for some help deciding what to do.
my options are putting a 4 link in. can anybody give me a good link for a bolt in kit. somebody recommended putting a trailing arm system in instead. do they make these in a bolt in kit? ive been trying to research but im not finding my golden thread with all this info yet. thanks for the help
kashimus is offline   Reply With Quote
Old 07-24-2016, 08:47 AM   #2
vin63
It's Better With Nitro
vin63's Avatar
Re: trailing arm vs leaf
It depends on what you plan to do with your truck. The leaf spring rear end is great for hauling and towing duties. If you want to convert it to a trailing arm suspension, here are a couple of links to the Classic Performance Parts and Ridetech kits (but you can piece it together to replace the coil springs with air springs).
http://www.classicperform.com/Store/.../6372TRS-K.htm
http://www.ridetech.com/store/1963-1...ar-system.html
There are numerous 4-link kits from No Limit, etc., that address all kinds of applications and installation skill levels.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 07-24-2016, 01:22 PM   #3
Brad54
Brad54's Avatar
If you want to convert it to trailing arm, the Chevys of the same year came from the factory with a trailing arm suspension. They're still plentiful in junkyards--you could either find one and cut out the t-arm cross member and add it to your GMC frame, or even just swap frames completely.
I'm a long-time hot rodder, and always opt for aftermarket stuff, but in this case, it's tough to beat the simplicity and price of a factory trailing arm installation.
-Brad
'61 Suburban daily driver: off the road due to 180-pound 8-pt buck!
'62 K-10 long-step project
'61 C30 Camper, aka "Valdez"
There's no cool like Old School
Brad54 is offline   Reply With Quote
Old 07-24-2016, 04:47 PM   #4
jtrichard
The cross member in my 63 GMC with leafs IS already the correct one for trailing arms (assume it is in the right location)and another GMC i just made into a trailer 68ish was the same just bolt the trailing arm brackets to the member (holes already there) and GO
jtrichard is offline   Reply With Quote
Old 07-25-2016, 01:38 AM   #5
Captainfab
60-66 Nut
I agree with just sourcing the parts from a '63-'72 Chevy. As said, the trailing arm crossmember should already be there.
Old 07-25-2016, 02:28 AM   #6
kashimus
thanks guys
