Old 07-24-2016, 04:32 PM   #1
fang508
What is the best intake gasket for a SBC with Holley 300-36 IM?
I have been doing some research about what style gaskets to use with aluminium intakes vs Steel. I bought a set of felpro intake gaskets 90314-1 from autozone and found out I might not be able to use them. It looks like they have a steel laminate core. I spent hours researching if these were actual steel cores and keep hitting dead ends. In the 90314-1 instructions it doesn't say what type of intake material is required to use them on. What exactly is the reason you can't use steel core gaskets on a aluminium intake? Also, if I can't use these then what part# should I look for? I don't want to have the take the intake off again lol. From what research I have done, what about these felpros 1256? http://www.oreillyauto.com/site/c/de...0584&ppt=C0226
fang508 is offline   Reply With Quote
Old 07-24-2016, 07:19 PM   #2
Jake Wade
Jake Wade's Avatar
Re: What is the best intake gasket for a SBC with Holley 300-36 IM?
Yes, use the Felpro 1256, I have many times, they work!
Jake Wade is offline   Reply With Quote
