Old 10-03-2003, 11:40 PM   #1
Zumo
Hot Rods For Life
Zumo's Avatar
Angry Son of a B***h!!!
So today is the day that I finally get my truck back together and running right?
A little history to present as short as I can make it.
The motor went out in my truck. Bad knocking. Found out it was a bad head. Broken pieces in vavle train. Get new 2 better heads, a month and a 1/2 later. Put new heads on today. Have trouble getting truck to start. Clean points, fired right up, knocking still there, not as loud, but none the less, still there. Bottem end bad. Rebuild inevitable. 500 spent thus far. Extreme frustration.
Son of a B***h!!!
1968 C10 LWB ****SOLD***
Andy
Viva Los Bicicletas!
Los Muertos Custom Bicycles
Zumo is offline   Reply With Quote
Old 10-03-2003, 11:45 PM   #2
low 84
low 84's Avatar
that sux man. i would have given you a good 4 bolt short block that you could put those heads on, but i gave it away a couple weeks ago
'51 F100, backhalf with a narrowed 9 and coil overs, 18.5" mickeys, monte front clip, +400" sbc in the works
'05 1500 Crew Cab
RIP
'84 swb 5/7 drop, solid cammed 408 w/ fully ported dart heads, th350 w/ 10 inch hughes, 12 bolt w/ 3.73 richmonds and a locker
'80 swb 4x4 in progress: 7" lift, 350 th350/np205, d44 and 1.5" ORD tie rod, 14BFF w/discs , armored diff covers, 40" MTR's
low 84 is offline   Reply With Quote
Old 10-03-2003, 11:47 PM   #3
Zumo
Hot Rods For Life
Zumo's Avatar
Ah don't say that brother.
I am hopeing it will all seem woth it tomorrow when I go to the Goodguys Show tomorrow and see all the cars and how each one probably had similar setbacks.
Andy
Old 10-05-2003, 12:12 PM   #4
Zumo
Hot Rods For Life
Zumo's Avatar
I guess right now I am going to wait to see if I can find a 350 shortblock to rebuild.
Andy
Old 10-05-2003, 12:39 PM   #5
Hutch
Hutch's Avatar
Zumo
There is a boardmember (bbs1965) that has a salvage business in Waxahachie and has a lot of truck parts.
Check with him and maybe you can work a deal.
Here is a post with his contact information.
I believe that he lives in Arlington and does the parts business on the weekends. I know that he states to be open on Sundays.
bbs1965
If you are looking for a rebuilt long or short block this will give you a ball park figure:
City Motor Supply
For replacement engine:
GoAutoCenter
Just some options to consider.
I have done business with City Motor Supply and they are a good engine shop and are have a fast turnaround but the last time I did some business with them it was cash only. The best bet with CMS is to have them rebuild your shortblock but be sure and mark it so that you get the correct one back,
John Hutchison
Grapevine,Texas
68 1/2 t swb
68 Mustang
69 Jaguar
71 1/2 t swb
88 Supra CompTs6m
93 Escort GT
2005 Corolla XRS
Hutch is offline   Reply With Quote
Old 10-05-2003, 02:25 PM   #6
Zumo
Hot Rods For Life
Zumo's Avatar
Cool. I have been looking fo some info. I found Blaine's motor supply www.blainesmotors.com Have you heard anything about these guys? They have a 72-79 350 4 bolt short block listed for 340.00. Seems like a good price to me. I'll have to check the other info you gave as well and compare. Thanks again man.
Andy
Old 10-05-2003, 03:56 PM   #7
lukecp
Formerly yellow72custom
lukecp's Avatar
Zumo, what do you mean it won't start?
If it is trying to start (sometimes hitting and backfiring), i would look into a incorrect valve adjustment, or messed up firing order. It could be possible you got the distributor in 180 degrees out.
Don't give up just yet.....if your shortblock had good oil pressure, and the bores looked nice and smooth when you yanked the heads, i would investigate getting it to start more before i started over with a new motor.
Good luck
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride.
'70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck.
'97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg
lukecp is offline   Reply With Quote
Old 10-05-2003, 03:57 PM   #8
lukecp
lukecp's Avatar
Oops, i just read your post better....you still have a knocking
$340 sounds like a good deal for a 4-bolt shortblock, but i have never heard of blaine's motors.
Old 10-05-2003, 10:46 PM   #9
Zumo
Hot Rods For Life
Zumo's Avatar
Yeah my guess is a spun bearing or something since there was NO damage to the cylinder walls.
Andy
Old 10-05-2003, 11:50 PM   #10
Stocker
20' Daredevil (Ret)
Stocker's Avatar
This is a very long shot, but does your truck have an auto tranny? A long time ago, my 350 started knocking badly, deep down in the block sounding like maybe a rod bearing. Turned out to be a cracked flex plate.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is offline   Reply With Quote
Old 10-06-2003, 12:02 AM   #11
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
A loose converter will do the ame...I've had that happen on a couple engines.
Old 10-06-2003, 12:08 AM   #12
progress
Gotta luv a clean shave
My buddy came over and asked me to listen to his knocking motor. I've heard too many rods and know this was not a rod. It would disappear at higher rpm. Turned out to be cracked bell housing! Just a thought. Rods are very loud and don't go away!
Welding while you wait...you can help if you like and it...might even save you a little as long as you don't mess things up!
We make house calls too...just like the old days!
progress is offline   Reply With Quote
Old 10-06-2003, 10:40 AM   #13
Zumo
Hot Rods For Life
Zumo's Avatar
You guys don't thina spun bearing would make this noise? I guess it's hard to tell unless you hear it for yourself.
Andy
