Old 07-25-2016, 01:27 PM   #1
Deano's 71
71 C10 350 rear main replacement
I want (need) to replace the rear main seal. I was hoping to do it with the engine in the truck. I tried but discovered there isn't enough room between the oil pan and the cross member. I plan on unbolting the motor mounts, the transmission cross member and the shift linkage, then raising the motor up 2 to 3 inches to remove the pan. Does anyone know if this will work or maybe a better way?
Deano's 71 is offline   Reply With Quote
Old 07-25-2016, 03:04 PM   #2
geezer#99
geezer#99's Avatar
Re: 71 C10 350 rear main replacement
That'll sorta work.
Watch out for the distributor cap when you raise it. Might need to pop it off.
And watch the bottom rad hose.
You likely don't need to loosen the tranny mounts or the shift linkage. Depending on which tranny.
And you might need to rotate the motor to get the front crank throw up out of the way to slide the pan out.
Old 07-25-2016, 03:30 PM   #3
Deano's 71
I didn't even consider the twist in the crankshaft, thank you. I really appreciate your "cautions", I have look all around the motor and there looks to be ample room. The tranny is a TH-350, I figured I would loosen it just to be on the safe side, I tend to break things. Thanks again.
Old 07-31-2016, 12:52 PM   #4
Deano's 71
Geezer#99, thanks for your help. I forgot to check the fan, it had to be removed or it was going to remove the shroud. A question you might be able to help, how can I realign the motor mounts by myself? I tried for about two hours, and no luck. Other than that it worked great.
Old 07-31-2016, 02:15 PM   #5
geezer#99
geezer#99's Avatar
Assuming you just removed the centre bolt from the bottom to seperate the mount, just grind a taper on the end of the bolt. So it looks like this bolt in the link.
http://www.chicagolandmgclub.com/techtips/mgb/101.html
Dress the threads and the bolt will thread right in.
Old 07-31-2016, 02:36 PM   #6
garyd1961
If it was me I would just go ahead and pull the motor. I've found that trying to take short cuts usually ends with the same amount of work and twice the frustration.
garyd1961 is offline   Reply With Quote
Old 07-31-2016, 03:41 PM   #7
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
This isn't a short cut. Many a rear main seal has been replaced with the engine in the vehicle. Not an "easy" job, but a doable job for the shade tree none the less.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 07-31-2016, 04:12 PM   #8
Shady Rascal
Shady Rascal's Avatar
Not a short cut at all. I can change one in the truck quicker than pulling the entire engine any time. Unbolt motor mounts and fan shroud, jack engine up and block motor mounts with wood. Drop torque converter dust cover, oil pan and oil pump and there you are.
A FelPro one piece pan gasket and FelPro Snap-Ups make it even easier.
Shady Rascal is offline   Reply With Quote
