Old 07-25-2016, 03:29 PM   #1
Bulldog88
Truck is running hot and can't figure out why
So my 2000 Silverado is running hot, replaced radiator 8 months ago, replaced water pump today, replaced all heater and water hoses and still gets hot don't know why, checked oil and it's clean, not milky like signs of a blown head gasket, it will run about 10-15 minutes and it will get up to 260 temp. It has fan shroud and every thing stock and can't figure out what's going on
Bulldog88 is offline   Reply With Quote
Old 07-25-2016, 03:31 PM   #2
Bulldog88
Re: Truck is running hot and can't figure out why
It's blowing the water out through the water tank reservoir, thru the hose
Old 07-25-2016, 03:52 PM   #3
Valarius_Starchaser
Valarius_Starchaser's Avatar
Thermostat?
"Orange Crush"
Valarius_Starchaser is offline   Reply With Quote
Old 07-25-2016, 04:53 PM   #4
Bulldog88
I've changed it out already
Old 08-18-2016, 06:29 AM   #5
68C15
blood type; Retumbo
68C15's Avatar
what temp is the coolant actually? Is the gauge reading right? The stepper motor in the gauge could be off. A scan tool might be of some help
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card
68C15 is offline   Reply With Quote
Old 08-19-2016, 09:42 PM   #6
Flying Hamster
Flying Hamster's Avatar
Pressure test the cooling system. Just because the oil is O.K. doesn't mean that the head gasket is O.K., only that it didn't blow into the oil system. Look for a cracked head or block.
What engine do you have? Early 4.8 had a porosity/crapulence issue with the Castech heads. Don't know if 5.3 uses same head.
Flying Hamster is offline   Reply With Quote
