Old 07-25-2016, 10:22 PM   #1
northerngmc
northerngmc's Avatar
Cracked exhaust manifold 396
Over the last couple of months I have noticed an exhaust leak on my 68 C20 with a 396, turbo 400. I thought it was probably a loose manifold or a collector gasket that was loose as the noise would go away once the engine warmed up.
Today I noticed that the left manifold has a crack in it!
Can an exhaust manifold be welded? I know it is is cast and this adds difficulty, but how much difficulty?
If I go shopping for another manifold how exclusive are bbc manifolds to trucks?
Any other reasonably suggestions?
The truck is fairly original and a bit of a survivor truck so I am not looking to go to headers or swap the entire exhaust system.
northerngmc is offline   Reply With Quote
Old 07-25-2016, 10:31 PM   #2
northerngmc
Re: Cracked exhaust manifold 396
Is it really this simple?
http://m.ebay.ca/itm/Exhaust-Manifol...256?nav=SEARCH
Old 07-25-2016, 11:10 PM   #3
70STOVEBOLT
70STOVEBOLT's Avatar
Yeah probably, I have seen s lot of repops. I think the big cars used the same ones.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear
70STOVEBOLT is offline   Reply With Quote
Old 07-25-2016, 11:30 PM   #4
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Wow........That looks pretty close to original. Edit, I have a spare LH side with a hairline crack. It takes up space and has no value. You need a "new" manifold.
Tony 1971 C10 Custom Deluxe SWB 402/400TH A/C
I developed an assembly information kit for restoring my truck from nuts and bolts. It's written in Assy. order, short & simple, packed with all OEM hardware ID; castings; part ID; 100s of part numbers; wiring simple - Resource, and trivial too.
Much info. applies to all 67-72 GM, A/C vehicles, esp. trucks W/O saying. Full search ability, including to 700+ images of illus., parts, charts, Assy., points of interest, cab, bed, & front clip cart plans- Specials and cores were serviced out and R excluded e.g. front/rear glass, body/paint, engine core, rebuilt hinges, steering box, trans, etc.
The project was in-line with long former professions developing process, policy, specs, demo, written for novices, admin., policy, engineers, development, systems & test - Public & govt 2, gross. Sell soft copy cheaply, PM if interested.
Build thread:https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 07-26-2016, 05:24 PM   #5
northerngmc
Where on the manifold should I look to find the casting number.
Old 07-26-2016, 05:57 PM   #6
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
Blaine I have a new repro exhaust manifold that came with a 70 BB truck I bought a few years ago. I'm not sure what side but can check tonight when I get home.
1992 K1500 GMC Suburban
" In the end, we only regret the chances we didnt take "
" Time is the only currency we spend without knowing the balance, use it wisely ." ..
Old 07-26-2016, 06:41 PM   #7
68Gold/white
They can be welded, also.
There's a special "cast" welding rod. You cannot use a grinding disc to clean out the crack, you have to use a carbide bit. They also make a "gouging rod" that is used ahead of the welding, some how it prepares the surface for the cast rod.
I'm no expert at all this, my good friend has a machine shop, showed me several years ago. It does work.
Nickle rod is NOT the same thing...
68Gold/white is offline   Reply With Quote
Old 07-26-2016, 08:26 PM   #8
northerngmc
http://www.yenko.net/ubbthreads/pics...8-img_0286.jpg
How different are bbc exhaust manifolds. Part number on the side 3914613. This does not align with the ATP cross reference in the eBay ad I posted above.
Old 07-26-2016, 08:49 PM   #9
hugger6933
It is not uncommon cracked manifolds were common even in to the squares and the 88-98 style as well.
hugger6933 is offline   Reply With Quote
Old 07-26-2016, 11:50 PM   #10
Already Gone
As luck would have it I have a right side exhaust manifold.
Old 07-27-2016, 12:02 AM   #11
Luvinit
Luvinit's Avatar
I,m needing a left one for my 72 402, I see LMC lists them also.
1972 Cheyenne Longhorn k20, 402, A/C
Luvinit is offline   Reply With Quote
Old 07-27-2016, 01:22 AM   #12
northerngmc
Thanks for checking.
Looks like my right one has already been replaced.
Old 07-28-2016, 12:56 AM   #13
71CHEVYSHORTBED402
The casting numbers can vary: Here's some info. most of which I lifted off SSTIM:
The following part numbers are service replacement parts.
But don't expect a number in the parts manual to match a part you pulled from your truck.
Overall its real simple, the replacement manifolds at the time of printing (5/79) were:
3994045 LH
333846 RH (3916178 to 3994046 to 333846)
with A.I.R. this is the air pump for emission reduction (Not A/C).
343787 LH
353030 RH
There is nothing on the parts manual page showing application specific parts for a 396-402 C10-30 Air Conditioned vehicle. If there were it would probably be notated w/AC, C.A.C., or C60.
