Old 07-26-2016, 01:32 AM   #1
paintinx
paintinx's Avatar
automatic trans temperature
hej, me again.
is there a special way to get the information about the automatic transmission temeperature during driving the car?
i am considering to set an instrument to my dashboard/bezel (one slot is free)
and than ... jau, what would be the best way to get the exact temperature?
in german it is called "temperatur geber" ....
thx, stef
paintinx is offline   Reply With Quote
Old 07-26-2016, 12:07 PM   #2
68Timber
I know the pieces fit
68Timber's Avatar
Re: automatic trans temperature
Sure, you just need to install the temperature sending unit in the transmission pan. Depending on the transmission, there may be a plugged port in the side of the transmission case that you can remove the plug from and install the sender there, but if I recall correctly, that spot may provide a high reading. Picking where you want to mount the sending unit is the only part that requires any thought, once you have that done and mounted you only have four wires to connect.
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 07-27-2016, 07:26 AM   #3
paintinx
paintinx's Avatar
thx John, I will discuss this with my "bastelfriends"
Stef
automatic temperature
