Old 07-26-2016, 04:11 AM   #1
tmoble
paint new repop steering wheel?
I have the re-pop 55-56 steering wheel. I want to two-tone it in India Ivory and Matador to match the rest of the truck. I have some PPG MP170 epoxy primer I've been using on the rest of the truck. Should I just scuff it hard with green scotchbrite, prime and paint? Any special primer needed for whatever it's made of? I'm sure the originals were Bakelite, but hard telling what kind of chinesium they're made of now. That thing wasn't cheap and I really don't want to butcher it up.
tmoble is offline   Reply With Quote
Old 07-26-2016, 03:22 PM   #2
OrrieG
OrrieG's Avatar
Re: paint new repop steering wheel?
I used epoxy 2k primer and regular base/clear on mine.
OrrieG is offline   Reply With Quote
Old 07-26-2016, 04:26 PM   #3
joedoh
joedoh's Avatar
Originally Posted by tmoble View Post
chinesium
I have been to factories in china. this is maybe the most accurate word I have ever seen.
the mass of men live lives of quiet desperation
if there is a problem, I can have it.
new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393
joedoh is offline   Reply With Quote
Old 07-26-2016, 04:38 PM   #4
Dan in Pasadena
Dan in Pasadena's Avatar
Wait a minute, WAIT a minute! That's NOT a TF steering wheel and especially not a '57-'59 wheel.
Own up to it Orrie, what's the story?!
'55 Big Window Shortbed,
Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's
Dan's '55 Big Window "Build" - Well, Kinda!
Dan in Pasadena is offline   Reply With Quote
Old 07-26-2016, 05:04 PM   #5
_Ogre
_Ogre's Avatar
oem would have been bakelite, chinesium is probably plastic and needs to be primed with plastic primer
similar to what we spray plastic interior and exterior parts
it may work fine just to use automotive primer, it's just that we use plastic primer on all plastic parts
shop air compressor timer
Old 07-26-2016, 07:55 PM   #6
OrrieG
OrrieG's Avatar
57-59 is dished. My eldo column stuck out enough I needed a flat one. 48 big truck was the first I found. dremel and JB weld fixed the cracks, thread over at HAMB on restoration gave advise on the the paint. Biggest issue was getting the stock horn button to work with the eldo mechanism, build thread has details. Here it is installed. Cannot tell from the photos but the it is metallic black. I used the same black to a/c vent trim.
Old 07-26-2016, 11:22 PM   #7
tmoble
plastic primer, never heard of it. Where do I get it? What's it called? Is it an SEM product? Oh, wait. nevermind, I have this thing called google......
Orrie, a man's gotta do what a man's gotta do.
Old 09-24-2016, 10:22 AM   #8
Foot Stomper
Foot Stomper's Avatar
I like the set up OrrieG!
What diameter is that wheel?
I am looking for some real estate between wheel on my 1959 and my t shirt.
So when is this "Old enough to know better" supposed to kick in?
My 1959 GMC build thread http://67-72chevytrucks.com/vboard/s...d.php?t=686989
Foot Stomper is offline   Reply With Quote
Old 09-24-2016, 11:02 AM   #9
47 Fasttoys
47 Fasttoys's Avatar
It looks to be the same wheel as my '47, if so it's 18"
Rob
My '47 C.O.E build
47 Fasttoys is offline   Reply With Quote
Old 09-25-2016, 09:16 AM   #10
Jemezcrusher
Did you use a cone file on your dremmel? What JB weld product?
Jemezcrusher is offline   Reply With Quote
Old 09-27-2016, 08:50 AM   #11
joe70
joe70's Avatar
try this on cracks of your steering wheel
joe70 is offline   Reply With Quote
Old 09-27-2016, 10:46 AM   #12
OrrieG
OrrieG's Avatar
I used a small grinding ball on the cracks. Trick is to under cut the edges so the jb is keyed in. I used the two part in the squeeze tubes. Metal file and 80 grit sandpaper to shape, then finer to finish. Single stage epoxy primer, 2x sealer and base/clear.
