Old 07-26-2016, 12:11 PM   #1
Mains52
Stretching an s-10 frame?
So the s-10 frame that I got for free is only a 108" wheelbase. I would like to keep my 3600 the stock length. Does anyone know if stretching the frame the extra 17 1/4 " will work. I calculated that much to retain the 125 1/4" stock wheel base. I plan on installing extra bracing to ensure the frame retains strength. Has anyone done this? Thanks
Mains52 is offline   Reply With Quote
Old 07-26-2016, 04:25 PM   #2
joedoh
joedoh's Avatar
Re: Stretching an s-10 frame?
there is a factory splice under where the door would be, you can grind it apart and add whatever length you need.
the mass of men live lives of quiet desperation
if there is a problem, I can have it.
new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393
joedoh is offline   Reply With Quote
Old 07-26-2016, 04:49 PM   #3
Mains52
Thanks Joedoh, I've read through all of your projects. Great Work.
Old 07-26-2016, 05:40 PM   #4
Black93GT
Black93GT's Avatar
this is the one that comes to mind right now. I'm sure there are others
http://www.code504.com/s-10-frame-wh...0-s-15-frames/
Black93GT is offline   Reply With Quote
