Old 07-28-2016, 10:33 AM   #1
michael bustamante
michael bustamante's Avatar
cam swap.
ok LS gurus here`s one for you
Can you take 6.0 stock cam with 3 holes and mount it in a 5.3 with a 3 hole cam. (2003 yukon) to wake up the engine? and if so what else would I need from the 6.0 donor?
1967custom
michael bustamante is offline   Reply With Quote
Old 07-29-2016, 07:40 AM   #2
Heavymetl
Re: cam swap.
Best way to "wake up" a stock 5.3 is a set of long tube headers and a tune. Another stock truck cam isn't worth the effort.
1970 C10
Turbo LM7 5.3/LS6 cam
PT7675/4L80E/Holley Dominator EFI/E85
Moser 9" 3.25/4 wheel discs
11.16@121.07
Heavymetl is offline   Reply With Quote
Old 07-29-2016, 09:36 AM   #3
Willie Makeit
Willie Makeit's Avatar
Re: cam swap.
yes it will work just fine, but it won't "wake it up" as you describe.
Heavymetl is spot on. Headers and tune are best "bang for buck." I have a 6.0 cam in a 5.3 and if you weren't told it had been swapped then you wouldn't know it. I'd even go as far as to say it is wasted effort.
Willie Makeit is offline   Reply With Quote
Old 07-29-2016, 04:36 PM   #4
NorCalAnthony
Re: cam swap.
If you're still wanting to do a cam swap take a look at Cam Motion or Brian Tooley Racing. They both have drop in camshafts for the 5.3 and 6.0 truck engines that are designed to work with the cheap LS6 valve springs and stock push rods and lifters to keep the cost to a minimum.
NorCalAnthony is offline   Reply With Quote
Old 07-29-2016, 06:27 PM   #5
michael bustamante
Re: cam swap.
ok guys thank you. i didnt know if it would make any real difference or not
1967custom
Old 07-29-2016, 07:23 PM   #6
LeesTruk
Re: cam swap.
Listen to what NorCal says. I put the Brian Tooley Stg.1 cam and LS6 spring in my otherwise stock 5.3L. It's docile until you want to play, then hang on!! And I can still get 19mpg(highway). I'm lovin' it. BTW, my truck is a '80 swb square
LeesTruk is offline   Reply With Quote
