Old 07-28-2016, 11:35 AM   #1
Madhatter0926
77 Camaro Subframe
Hey guys,
I'm currently rebuilding a truck that was my dads. It's stripped down to the frame. I don't have a great deal of information about what my dad did to the truck when I was young because he passed away. I do remember him saying he put on a 77 Camaro subframe or something similar. I'm starting to build the frame and I need to know what parts to buy. Is there a way to tell what parts on the subframe are 77 Camaro and what's 65 C10? This is my first complete rebuild.
Also, why convert the subframe to 77 Camaro? Increased handling?
Dustin
Madhatter0926 is offline   Reply With Quote
Old 07-28-2016, 12:18 PM   #2
Raked 64
Raked 64's Avatar
Re: 77 Camaro Subframe
Lots of smart people on this site. Post a few pictures and I am sure we can help you figure out what parts you need.
Raked 64 is offline   Reply With Quote
Old 07-28-2016, 12:21 PM   #3
DURG
DURG's Avatar
70-81 Camaro sub frames are common on 59 and down trucks. I have not seen many on the 60 and up. I would think all of the parts on that sub frame would be used such as ball joints, tie rods, bushings etc. If the Camaro spindles were used, they did have 2 different size outer bearings used through the years. Older were an A2 then at some point they went with bigger A3 outers. Inners should be A6's. I would also expect the idler arm, center link should have remained 77 Camaro too. The brake calipers could also have metric or American banjo bolts too which would require a different rubber brake line. I think 78 to 81 were metric but can't swear to it. Not that it matters in your application but the rear mount location for the frames changed at some point, I think 74.
1962 Impala SS 383 stroker Tremec TKO 600 Black
1965 SWB BBW Fleetside Custom Cab PB Coilover setup Black
2003 100th Anniversary Road King Classic Silver Black
DURG is offline   Reply With Quote
Old 07-28-2016, 12:23 PM   #4
DURG
DURG's Avatar
If a Camaro subframe is run at the right "frame height", it has very good handling characteristics. Also something to think about regarding wheels is your treadwidth compared to stock.
Old 07-28-2016, 12:25 PM   #5
DURG
DURG's Avatar
Tons of aftermarket suspension components available for the Gen 2 Camaro clips from folks like RideTech and Detroit Speed as well as many others. Google "second generation f body suspension" should lead you to all kinds of fancy (read expensive) options.
Old 07-29-2016, 06:39 PM   #6
Madhatter0926
Thanks for the replies guys. I posted some pictures to see if someone can tell me if I do have a 77 subframe.
Also, do these sway arms look right?
My dad had about 3 cars worth of parts in his garage when he passed. So I'm trying to figure out what he had in the truck when it was running. Thanks for all your help!
Dustin
Old 07-29-2016, 09:03 PM   #7
DURG
DURG's Avatar
I can tell you those are not Camaro upper or lower control arms.
Old 07-30-2016, 01:01 AM   #8
Captainfab
60-66 Nut
Those are '73-'87 C10 control arms, spindles and steering linkage.
Old 07-30-2016, 07:52 AM   #9
Madhatter0926
Well dang, I'm not sure why I thought it was 77 Camaro. Thanks for telling me. What's the purpose of using control arms and spindles from those years?
Also, these will fit on my 65?
Old 07-30-2016, 11:41 AM   #10
chevy_mike
Never Ending Projects
chevy_mike's Avatar
It would be to allow a cheap way to upgrade to disc brakes. Swapping all the same parts over makes for a simple, easy swap. Yes they will fit your '65 but you might have to drill some new holes for the idler arm on the frame, since this designed changed over the years.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 07-30-2016, 06:14 PM   #11
DURG
DURG's Avatar
Can we see a picture of the frame. The Camaro and the truck frame are not the least bit similar.
Old 07-30-2016, 10:11 PM   #12
Madhatter0926
I think I may have figured out what happened. I think my dad used 77 Camaro spindles with 73-87 control arms to convert to disc brakes cheap. The 77 camaro subframe got added into my head at some point. Here are some pics, let me know what you think.
Old 07-30-2016, 10:31 PM   #13
Madhatter0926
Here are the pictures.
Old 07-30-2016, 11:20 PM   #14
jtrichard
Well the frame is OEM C10 truck FOR SURE... cross-member is Chevy truck others can tell by the pic about what year i bet .....Since dad said something about a 77 i bet the donor was a 77C10 chevy
jtrichard is offline   Reply With Quote
Old 07-31-2016, 08:23 AM   #15
Madhatter0926
Thanks for helping me figure that out guys. Now it's time to buy parts.
Any suggestions on a front end kit? I want to buy drop spindles, rotors, tie rod ends, calipers, bushings, etc. Any advice on where I could buy all everything I need for the front end suspension in one kit?
Old 07-31-2016, 09:10 PM   #16
TopFuel1966
TopFuel1966's Avatar
Early Classic Enterprises
www.earlyclassic.com
TopFuel1966 is offline   Reply With Quote
Old 08-01-2016, 10:55 AM   #17
chevy_mike
chevy_mike's Avatar
x2 on that. ECE is top notch! Just remember, you are buying parts for the suspension stuff you have, not the year of the truck.
