Old 07-28-2016, 12:55 PM   #1
ApacheNick
Got a 348 for my 61
So I just got a 348 with a tri-power intake for my 61 step side and I'm just wondering if there's anything important I should know about these engines before I get started with the rebuild.If anyone knows of any good books or websites about these it would be a big help.
Nick
1961 Apache short stepside 4X4 SBW 348/4 speed
1960 Apache C-20 long fleet custom cab BBW 283/4 Speed
1967 rust bucket Olds Cutlass with a 455
1972 GMC K-15 350/4 speed long fleet
ApacheNick is offline   Reply With Quote
Old 07-28-2016, 01:01 PM   #2
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
Re: Got a 348 for my 61
I stuffed a 409 into my truck at one time and for clearance I had to nudge the firewall on the passenger side to be able to remove the valve cover. I used a hydraulic spreader.
Old 07-28-2016, 01:03 PM   #3
Ronzo
Ronzo's Avatar
http://www.348-409.com/forum/
Ronzo is offline   Reply With Quote
Old 07-28-2016, 06:06 PM   #4
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
I can't help with the subject, but I will say I hope you post up lots of pictures!
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline   Reply With Quote
Old 07-29-2016, 10:17 AM   #5
MikeN
MikeN's Avatar
Awesome! I would love to put a W motor in my 64. Congratulations!
MikeN is offline   Reply With Quote
Old 08-01-2016, 08:30 AM   #6
1963c-10
1963c-10's Avatar
Thread on 348-409 powered trucks on this forum
http://67-72chevytrucks.com/vboard/s...d.php?t=630055
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 06-18-2021, 02:43 AM   #7
ApacheNick
Well I'm reviving this old thread because I finally got this engine set into this truck and there are some problems.
The big one is that using the stock mounts for the bell housing/transmission I can't get the left cylinder head on. It hits the firewall before the rear dowel pin lines up.
We are thinking about making a custom spacer set to move the engine forward but leave the bell where it belongs. This would be a 2 part set. One spacer for between the block and bell and one for between the crank and flywheel.
What do you guys think?
Nick
Old 06-18-2021, 08:00 AM   #8
mongocanfly
Post Whore
mongocanfly's Avatar
My 2 cents worth..
either modify firewall or move engine mounts forward
Not saying spacers wont work, but it sure won't be ideal....how thick of spacer are you talking?
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 06-18-2021, 10:58 AM   #9
jayoldschool
Moderator
Unbolt engine and trans from mounts, tilt, install head, tilt back and see what hits. Fix that, bolt it down.
jayoldschool is offline   Reply With Quote
Old 06-19-2021, 03:48 PM   #10
ApacheNick
Originally Posted by mongocanfly View Post
My 2 cents worth..
Well it looks like I won't need a spacer after all.
I figured out that I can get both valve covers on. The right one is not easy but it does fit.
As for the left head hitting the firewall, I forgot that I haven't got the new cab support bushings installed yet so we'll see what it looks like after I do that.
Nick
