07-28-2016, 08:38 PM | #1 |
Senior Moment
What are you using for throttle cable
What are you LS guys using for a throttle cable ?? My original one obviously won't work. Does anybody after market make one ??
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN 2013 GMC PU, Oldest Son 71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son 2017 Toyota SUV Daughters car 2018 Traverse , Wife’s Ride Pittsburg Ca 94565 |
07-28-2016, 09:13 PM | #2 |
Post Whore
Re: What are you using for throttle cable
I used the cable from a 01 truck on my 81...had to file the firewall hole a little bit but it worked perfect.
07-28-2016, 09:32 PM | #3 | |
Senior Moment
Lokar is expensive
07-28-2016, 10:12 PM | #4 |
Post Whore
I think I gave 5 bucks for it at a junkyard..I just held a piece of paper up to the firewall and traced a pattern for the firewall hole and transferred it to my 81 over that cable hole and then opened what needed removed with a file..the ls cable just snapped in place..my gas pedal was already a cable pedal..if yours is a rod type you might want to grab the pedal to..
07-29-2016, 12:09 AM | #5 | |
Senior Moment
Thanks Steve
07-30-2016, 11:13 AM | #6 |
my truck is 76-ish we used the cable that came with the 2002 engine
the metal cable was a little bit to long where it hooks to the gas pedal and I just looped it around a 9mm socket and used a cable clamp to take up the slack. |
08-05-2016, 10:33 AM | #7 |
Mountain bike brake cable here.
Matt Cramer 1972 Chevy C10 - 4.8 swap, long bed, and maybe one dent free body panel somewhere - SOLD 4.8 LS build thread |
08-06-2016, 12:01 AM | #8 |
Senior Moment
Found exactly what I needed at the wrecking yard. LOL Ca price $20
Thanks all for your input
