Old 10-04-2003, 12:40 PM   #1
Z28Owner
Z28Owner's Avatar
Just finished auto swap...
Linkage came in from Kugel yesterday and finished up my swap so I can drive it now. Anyways the speedometer gear is off, which I will change later. But for now I was just gonna use the tach to monitor my speed and was just wanting to know if the final drive gear is the same on a TH350 as in the factory 3 speed. And is there any calculators for figuring up the gear I need. I have a 307/350 LWB truck with 4:11 gear and 235/70/15 tires. Thanks.
1971 LWB Chevy C-10
350/350 3:42 eaton
Z28Owner is offline   Reply With Quote
Old 10-04-2003, 12:52 PM   #2
70c10
67-72 Addict!
70c10's Avatar
Is this what you need? http://www.tciauto.com/components/speedometer_gears.htm
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 10-04-2003, 10:13 PM   #3
project1971
project1971's Avatar
try this i used it and was dead on. http://www.cvsr.net/php/links.php
the final drive for the 3 speed and the th350 is 1:1 all the final drives are 1:1 unless it has over drive the the 3rd gear is 1:1
hope this helps
2008 Ford FX2 Screw
1971 C10 project in shop now!
2004 Pontiac Grandam (wifes)
2000 Cavalier z24 (gas saver)
project1971 is offline   Reply With Quote
Old 10-06-2003, 06:56 PM   #4
justplainjoe
justplainjoe's Avatar
How hard was the swap? What all was involved. I am wanting to do the same on my 72 GMC. Thanks JPJ
justplainjoe is offline   Reply With Quote
