Old 07-30-2016, 11:03 AM   #1
50dude
50 gmc blinker switch
I have original blinker switch rewiring truck on switch there is 7 wire
Yellow /red/green/brown/blue/gray /gray black can you guys tell me whats what thanks
50dude is offline   Reply With Quote
Old 07-30-2016, 12:40 PM   #2
mongocanfly
Post Whore
mongocanfly's Avatar
Re: 50 gmc blinker switch
Do you have one of those universal add on blinkers?..http://www.classychevusa.com/index.c...92/prd1592.htm
Old 07-30-2016, 01:28 PM   #3
50dude
no original
Old 07-30-2016, 01:40 PM   #4
mr48chev
mr48chev's Avatar
Those were all aftermarket switches that were either installed at the dealership, an independent shop or the owner.
Here is one common switch that has been around for a long time and is still sold. The diagram should be reasonably close.
I've figured them out before with an ohm meter or a continuity tester to tell where the wires go.
if it has the setup for 4 way flashers it is post 1965 as that was about the time they came out with 4 way flashers.
My ongoing truck projects:
Old 07-30-2016, 01:47 PM   #5
mongocanfly
Post Whore
Post a pic of what you got..I looked thru my assembly manual and there's no wiring in the schematic for blinkers thru 54..has some past owner changed out your column by chance?
Old 08-01-2016, 01:10 AM   #6
mr48chev
mr48chev's Avatar
Not to be short with you 5oDude but no 50 Chevy pickup came from the factory with turn signals. They were added on at the dealer or added on by a shop or the owner who bought them at a parts house. Pre 1965 most only came with one hot wire in and wires for the front and rear signals. Those signals were the ones that you see on top of the front fenders in most cases and the extra light on the back of the trucks. Later they rigged them to work with the brake lights for the rear.
Post some photos of your switch and one or the other of us can figure out what you are working with.
Old 08-01-2016, 02:44 PM   #7
50dude
figured it out thanks
Old 08-01-2016, 02:49 PM   #8
mongocanfly
Post Whore
What did you figure out..? Just curious...
