Old 07-30-2016, 01:59 PM   #1
jbgroby
jbgroby's Avatar
Placement of door weather strip
Hi gang,.
Can post some pictures of the door weather strips? I want to make sure I'm placing them correctly.
Jake
jbgroby is offline   Reply With Quote
Old 07-30-2016, 07:51 PM   #2
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Re: Placement of door weather strip
Ummm... there is no weather stripping that goes on the door. It goes on the pinch weld flange on the body.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 07-30-2016, 09:00 PM   #3
T and S
T and S's Avatar
X 2 ^
If you don't like this pound sand .....
T and S is offline   Reply With Quote
Old 07-30-2016, 09:22 PM   #4
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
Old 07-31-2016, 07:54 AM   #5
jbgroby
jbgroby's Avatar
Ok thanks guys. I wonder why Steel Rubber sells it like that. Does anyone know when the started with the door rubber? Unless I was confusing another year, my faulty memory seems to think I've seen rubber on the door. Maybe when I bought my door they were from 61-63?
Old 07-31-2016, 11:23 AM   #6
bhc41051
bhc41051's Avatar
I believe the rubber door gasket was 60-61. I think there's an illustration in the build manual. I do know there's a screw with a small clip that holds one end or both. Sorry I'm so vague I've sold/given away all my 60-66 reference material and returned to my square-body roots.
bhc41051 is offline   Reply With Quote
Old 07-31-2016, 03:20 PM   #7
jbgroby
jbgroby's Avatar
Ok, I spoke with a few members who have a 60 and they did use a door weather strip. I have make the two metal slips for the doors. Thank ks for all the replies. They stopped doing the door strip with the 62 model year it looks like. This is another entry on the correct restoration thread.
Old 07-31-2016, 09:13 PM   #8
jbgroby
jbgroby's Avatar
I spoke to Arthur Throckmorton and he explained that the 60-61 doors did have the door ruber and they will leak if it is not used. Another member send some pictures of doors with the gasket. I have to make the metal brackets, however, with the new 3-m glue, I wonder if I actually need the brackets.
