Old 07-30-2016, 02:16 PM   #1
tjsblazer
tjsblazer's Avatar
72 front tow hook hardware size ??
My tow hooks weren't on from the factory so I would like to know what the factory hardware was to hold them on. This is for a 72.
Size, washers, etc. Thanks.
Jeff.
'72 Blazer K5
"Camshaft opinions are like belly buttons; everyone has one and no two are alike"
My Blazer Build:
http://67-72chevytrucks.com/vboard/s...d.php?t=626752
My Engine Build:
http://67-72chevytrucks.com/vboard/s...d.php?t=637336
tjsblazer is offline   Reply With Quote
Old 07-30-2016, 02:21 PM   #2
Jeff's bowtie's
Re: 72 front tow hook hardware size ??
The bolts are 5/8" with 15/16" hex heads not sure about the length maybe 3 1/2" tractor supply grade 8
Jeff's bowtie's is offline   Reply With Quote
Old 07-30-2016, 02:36 PM   #3
tjsblazer
tjsblazer's Avatar
Course or fine thread. Did they have any washers used?
Jeff.
'72 Blazer K5
My Blazer Build:
My Engine Build:
Old 07-30-2016, 02:43 PM   #4
Jeff's bowtie's
Course not sure about washers
Old 07-30-2016, 05:51 PM   #5
bluek5
bluek5's Avatar
Jeff,
I just went out and looked at my 72 Blazer. The one you asked about the spid. No washers other than lock washers under the nuts.
Paul
bluek5 is offline   Reply With Quote
Old 07-30-2016, 06:06 PM   #6
tjsblazer
tjsblazer's Avatar
Thank you Jeff.
Originally Posted by bluek5 View Post
Jeff,
Paul
Hey Paul thank you for the confirmation. Next time you are out there could you confirm the length for me. They look like the exact length needed with just a couple of threads exposed after tightening.
Jeff.
'72 Blazer K5
My Blazer Build:
My Engine Build:
Old 09-13-2016, 03:35 PM   #7
bluek5
bluek5's Avatar
Originally Posted by tjsblazer View Post
Thank you Jeff.
Jeff,
I know it has been months since you asked about the hardware. Better late than never.
Old 09-13-2016, 04:47 PM   #8
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Not oem but heres what i have fwiw. Grade 8 cadmium that i had black phosphate coated.
Old 09-13-2016, 07:30 PM   #9
69-72
69-72's Avatar
Might want to throw a weld on the threads after you bolt them on. I did.
1969 Chevy Custom Camper 3/4 ton Rust free survivor
1972 Chevy Blazer CST 4x4 Almost Rust free survivor
1972 GMC Jimmy 2wd Undergoing surgery
69-72 is offline   Reply With Quote
Old 09-13-2016, 09:24 PM   #10
In The Ten Ring
Is that to prevent theft?
In The Ten Ring is offline   Reply With Quote
Old 09-13-2016, 10:00 PM   #11
tjsblazer
tjsblazer's Avatar
Thanks everyone.
When I dug out the set of Front tow hooks I had (bought off this board several years ago) they had the hardware with them that I had forgotten about.
Measured the same 2.5" that both Paul and Pete are showing.
Jeff.
'72 Blazer K5
My Blazer Build:
My Engine Build:
Old 09-13-2016, 10:39 PM   #12
69-72
69-72's Avatar
Slow it down at least
Old 09-13-2016, 10:55 PM   #13
In The Ten Ring
I thought so. Well these hooks sell for what I consider quite a bit on this site so yes, I could see where anti theft measures would be attractive.
