Old 07-30-2016, 06:16 PM   #1
oldpurple
New drum brake hardware - clip?
I'm in the process of doing my rear drums and my new hardware kits have come with a couple of these little clips. I didn't remove any during disassembly so I'm not sure where they are supposed to go.
http://i.imgur.com/YntcAeN.jpg
oldpurple is offline   Reply With Quote
Old 07-30-2016, 07:18 PM   #2
foamypirate
foamypirate's Avatar
Re: New drum brake hardware - clip?
They go in the backing plate. They are to close up the inspection hole through which you can check the lining thickness. There should be a rubber plug for the adjuster hole as well.
foamypirate is offline   Reply With Quote
Old 07-30-2016, 07:21 PM   #3
oldpurple
Thanks. I'll have to take another look. My backing plates do not have the hole for the adjuster which I thought was odd, but I did a search on here and it seems like it's not that uncommon. I have read that there might be a knockout on the backing plate for an adjuster hole. I will have to clean them up and have a closer look.
Old 07-31-2016, 03:06 PM   #4
69heavychevy
69heavychevy's Avatar
When I completely rebuilt my rear brake system I couldn't figure out where those went. I didn't see them anywhere when I torn down the old brakes...so I just tossed them lol...
80 C10 SWB Step Side - 350 w/ vortec heads, TH350, 12-bolt 3.73
69heavychevy is offline   Reply With Quote
