![]() Join Date: Oct 2012
R4 compressor on small block image needed.
I'm having an odd alignment problem. I have a 86 305, replaced the frozen factory Harrison with a new, not rebuilt, from Napa and I can't seem to get the belt to line up right. I also can not get all three of the rear mounting bolts lined up at the same time. If someone could snap a pic from the drivers side that shows both the mounting brackets and share that would be great. Hopefully that will tell me if I've done something wrong, or its the compressor. Thanks.
One of these two views is what I'm looking for ![]() ![]() It's hard to see in this picture, but the compressor is "tilting" backwards and the belt is at an angle to the water pump. The compressor needs to be moved towards the front of the truck, as well as the top needs to be clocked a few degrees forward. ![]() Last edited by jdl71; 07-31-2016 at 08:46 PM. |
![]() Join Date: Apr 2009
Re: R4 compressor on small block image needed.
This was the setup on my 83 C20 5.7
Looks like a spacer is missing at the rear bracket, also belt looks too long, should have more slot travel to tighten. Desert |
Do you still have the old compressor?
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
Lesson learned. I never give up my core til my car has been running for a good while. I understand funds can get in the way. I gave away a very valuable carb once and didn't realize til it was too late.
Yes I do. When I change out the hoses I'm going to compare them side by side.
#7 | |
