07-31-2016, 05:44 PM | #1 |
Another 2 piece driveshaft angle question
Here are current angles on mildly static lowered 1991 suburban
tailshaft angle -2.6 slope down towards center support bearing 1 shaft angle -3.6 slope down towards center support bearing 2nd shaft -1.3 slope down towards center support bearing pinion angle -4.8 slope down to ground all angles as posted have a - slope. Do these fall within range, there's a very minor vibration at 45-85, brand new wheels and tires, even before with the old stock factory wheels,had same slight vibration. Also those listed angle above are very close to the before lowering of the vehicle at factory height.,lastly vehicle has 64k original,and i've serviced since new. |
07-31-2016, 06:57 PM | #2 |
Re: Another 2 piece driveshaft angle question
correction
all slopes are negative 2nd shaft angles towards rearend pinion angle point's up so it's negative as well using the spicer operating angle app operating angle 1 is 1 operating angle 2 is 2.3 operating angle 3 is 3.5 do these angle's seem to be allright btw- u-joints all tight,center carrier bearing no play,axle bearings,rearend,all ok. Last edited by Koz1; 07-31-2016 at 07:04 PM. |
07-31-2016, 09:30 PM | #3 |
I've always been told that the angle should be kept within 1 degree to minimize driveline vibration. Sounds like your rear end needs to rotate up a few degrees
08-01-2016, 10:59 AM | #4 |
Deleted.
08-02-2016, 07:00 AM | #5 |
08-02-2016, 08:48 AM | #6 |
While the Spicer info is correct, if you ask anyone w/knowledge on the subject, as soon as the rear-end is higher than the other driveline parts the numbers yield different results.
The best results I got w/my dually was aiming the rear pinion toward the carrier bearing while not keeping it straight.
08-03-2016, 07:12 AM | #7 | |
08-03-2016, 03:25 PM | #8 | |||||
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 08-03-2016 at 03:32 PM. |
08-03-2016, 08:05 PM | #9 |
tailshaft down 2.6 toward ground
first shaft down 3.6 toward carrier bearing/ground 2nd shaft down 1.3 toward ground/rearend pinion 4.8 pointed up to sky thanks, i tried to edit very first post to make it simple but it wouldn't let me edit,i'm guessing there's a time lock after a post? |
