Old 07-31-2016, 10:47 PM   #1
geasson
1966 1-ton project
I recently bought a 1966 GMC one-ton with factory stake side bed. It only has 9800 miles on it and I believe that when you look under the cab and under the dash. The motor is a 305 V6 with a 4-speed. The seat and floor mat are original. The bed is rotted and I took it all off today.
So, far I have had to pull the gas tank, FULL of rust. A new tank and sending unit has been ordered. I watched all the videos and read all the stuff about cleaning a tank and decided that mine was too far gone.
Attached are a couple of pictures before starting on it. More to follow. Not sure if I will restore or just get it running and drive it. No dents, no rust holes ANYWHERE.
geasson is offline   Reply With Quote
Old 08-01-2016, 06:36 AM   #2
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
Re: 1966 1-ton project
Very nice historic piece. Pictures for reference under the hood would be handy.
Give it a bath!
Old 08-10-2016, 10:44 PM   #3
geasson
Had a good weekend working on the truck last weekend. New tank and sending unit install and finally running, not well, but running. Carburetor is in desparate need of a rebuild, that may be next. Not sure if I will try and to it or find someone to rebuild it. The attached pictures show the original floor mat (cleaned), and some other pictures of the underside. The PO says that the 9800 miles on the odometer are original miles.
Old 08-10-2016, 11:06 PM   #4
geasson
A couple more pictures
Old 08-11-2016, 01:03 AM   #5
TJ's Chevy
TJ's Chevy's Avatar
Hi an welcome! Very nice truck there! A common upgrade on these 305's is to convert to a 500 cfm holley 2 barrel and dual exhaust. Also an HEI helps a lot as well. Makes for a nice little increase in power and you can put some better mufflers on there(if you want a different tone). I did a 600 cfm 4 barrel mod on my 305, dual exhaust, HEI with the msd 6al box. With flowmaster 40's it pulled way better than stock and sounded great! Currently doing a complete reseal and light rebuild on it. Rebuilding carbs is fairly easy long as you keep in mind how things come out and put them back in the same way. Also be sure to set things to spec. I would also pull those valve covers and make sure all the valves are in spec as well. .012 intake and .018 exhaust. It is a common thing for some shade tree mechanic to sinch them down and then the engine will perform poorly. Have any questions don't hesitate to ask! And if your not subscribed here: http://6066gmcclub.com/index.php I would encourage you to join us!
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline   Reply With Quote
Old 08-11-2016, 08:26 AM   #6
geasson
THanks for the info, I am subscribed to the 6066 page as well. I will post some pictures and info as well. I am not sure what I am going to do with my truck, keep it or sell it. I have too many projects, but this one was a unique piece. My Dad was a GMC dealer for 47 years, starting in 1954 and we had a wrecker
with a V6 that we drove forever.
I am going to get the bed on my truck sandblasted and painted and new wood and then decide what to do.
Old 09-12-2016, 09:02 AM   #7
jesseo
jesseo's Avatar
Love it. I just bought a 63 one ton. Need to pick it up next week and find out what straight six I have. I will be following your progress for sure.
jesseo is offline   Reply With Quote
Old 09-12-2016, 10:37 AM   #8
clemdaddy
clemdaddy's Avatar
Nice find... always had a soft spot for those one ton'ers. Finding an original bed that straight is next to impossible... Congrats
clemdaddy is offline   Reply With Quote
Old 01-23-2017, 10:55 PM   #9
geasson
Haven't had a chance to do much on my 1-ton, the fall was really busy and now I am trying to put my CJ2A back together. Too many projects and not enough time. I still plan to get the bed sand blasted and possibly powder-coated and then put in new wood.
Contemplating rebuilding the existing carb or putting on a new Holley. Opinions???
Old 01-23-2017, 11:47 PM   #10
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Clean truck.
66 C20 Service Truck:
Old 01-25-2017, 09:42 PM   #11
geasson
I need to rebuild some of my original stake sides. Anyone know where you can get the nuts that go onto the carriage bolts? They leave a flat surface that locks into the wood.
Old 01-26-2017, 12:59 AM   #12
Captainfab
60-66 Nut
I'm not quite sure I understand what these nuts look like. Are they flange nuts? Can you post a picture?
Old 01-26-2017, 08:39 AM   #13
DPowers
DPowers's Avatar
Here maybe?
https://shop.stafast.com/t-nuts
DPowers is offline   Reply With Quote
Old 01-27-2017, 01:46 AM   #14
Captainfab
60-66 Nut
I thought of those, but I just don't think those will work with carriage bolts
Originally Posted by DPowers View Post
Old 01-27-2017, 09:03 PM   #15
Moarplease
Whiz or wiz nuts. Also called serrated flange nuts.
Adam
Moarplease is offline   Reply With Quote
Old 01-29-2017, 01:28 PM   #16
geasson
This is what the fasteners look like.
Old 01-29-2017, 03:30 PM   #17
Moarplease
That's a It backside. Screw or bolt head on the inside?
Adam
Old 01-29-2017, 03:31 PM   #18
Moarplease
If it's an actual carriage bolt then that special bolt is no longer produced I'd bet.
Adam
Old 01-29-2017, 04:53 PM   #19
geasson
That is the back side of what appears to be a carriage bolt. They look like a special tool is required to put them in.
Old 01-29-2017, 09:30 PM   #20
Moarplease
Not exact but a sex bolt or barrel bolt would work well.
Adam
Old 01-30-2017, 01:01 AM   #21
Captainfab
60-66 Nut
Those are a specialty nut that takes a special socket or spanner wrench to install them by grabbing the 3 notches. I have not seen anything like those before. If you need them, they will likely need to be custom made. They really wouldn't be that hard to make.
Old 01-30-2017, 05:03 PM   #22
clemdaddy
clemdaddy's Avatar
i've seen those on old wood side racks before and i think that the 3 holes are punched so that they become a spike on the other side. as you tighten the bolts they stab the wood to prevent it from turning... of course, i'm usually wrong.
have you removed one yet?
Old 01-30-2017, 05:15 PM   #23
Bomp
Bomp's Avatar
Welcome, cool truck, I'm in.
Bomp is offline   Reply With Quote
Old 01-31-2017, 09:23 AM   #24
coyn
They're not exactly the same but I have used T-nuts to do something similar in wood parts that I have made in a previous job. They lock into the wood and allow you to bolt through them. They work very well.
https://www.amazon.com/Hillman-Group...5868899&sr=1-1
coyn is offline   Reply With Quote
Old 02-02-2017, 11:56 PM   #25
geasson
I have not removed one yet. It looks like the carriage bolt was pushed thru the hole and then these were screwed on with some sort of special tool. I need to get one out to see what they look like, but I wanted to see if anyone had rebuilt original stake sides.
Thanks for all the good info and input. Your help is appreciated.
