Old 08-01-2016, 06:13 AM   #1
1fast10
Boyds gas tank in 71 suburban
Has anyone used boyds tanks in a suburban.how well do they fit and is there nay filler neck modifications
1fast10 is offline   Reply With Quote
Old 08-01-2016, 10:38 AM   #2
SIXTY9CST
Re: Boyds gas tank in 71 suburban
I have a Boyd's efi tank in my 68 burb. Great product! The filler neck needs to be moved forward and the filler neck should be 1 1/2" diameter. I also recommend the mounting kit. It will make the install way easier.
SIXTY9CST is offline   Reply With Quote
Old 08-09-2016, 05:36 PM   #3
magntik
I've got one installed in my '72 C20.
Fit great. spend the money and buy his pump/sending unit sent up if you're fuel injected, it'll save you some time,
I agree the only issue I had was the fill tube diameter.
magntik is offline   Reply With Quote
Old 08-09-2016, 05:56 PM   #4
1fast10
What did you have to donwith filler neck diameter to make it work
