08-01-2016, 03:09 PM | #1 |
AC controller & blower motor questions
Now that my 70 is driveable, the next thing will be to get the AC functioning. (probably just in time for winter.) I was just wondering about the AC controllers. What are the odds mine still functions OK? Is it better just to buy a repop, or an original GM, or a restored one?
Also, my blower motor works great on all settings but high. The fan speed switch is new. What else should I look at? Sounds to me like a ground issue, since high is a full 12v.
Running in place gets you nowhere fast. -me 1968 GTO 4-spd covnvertible 1970 K-20 4-speed, factory AC. |
08-01-2016, 04:17 PM | #2 |
Re: AC controller & blower motor questions
You won't know about the controls till you try them. Often the cables get stuck. The levers break. All parts are available for them. They are not hard to o-haul. The high blower has its own fuse. It is in line near the junction block under the hood. Also there is a high blower relay mounted on the plenum under the hood. They are notorious for failing.
08-01-2016, 04:52 PM | #3 |
My blower motor was doing the same thing and I found it was a bad ground at the motor.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
08-01-2016, 05:56 PM | #4 | |
I will look for the relay but a lot of stuff got stripped away by a PO, so hopefully it is still there. I have a feeling it isn't, as I've not noticed any relays there. But, I can't even remember where they hid the horn relay on these things.
08-01-2016, 09:32 PM | #5 | |
1971 Cheyenne SWB 402BB, 700R4, 3.73 posi, PS, PB, A/C, Tilt, Tach "Wanda" Don't argue with idiots, People watching may not be able to tell the difference... There's someone in my head........But it's not me...... cheap tricks thread great info here!! http://67-72chevytrucks.com/vboard/s...d.php?t=489394 |
08-02-2016, 03:13 PM | #6 |
I found a relay behind the vacuum pod on the passenger side, it was attached to the AC airbox. There was a ground attached to the mounting screw. Still need to track down that fuse.
Guessing new levers should be installed by default, and cables as well.
08-02-2016, 05:46 PM | #7 |
Funny= I have a 72 and a 70. My 72 is the only one with Air but I have pulled and reworked both harnesses and don't know about this fuse either. If it is there I must have just replaced the fuse and kept on a wrapping those harnesses.
08-04-2016, 11:25 AM | #8 |
Trucks don't have a fuse, but cars of this era did. The relays are know for going out because they're mounted upside down, and a leaky windshield (not that any of these trucks have that problem... ) will allow it to fill with water and rust it up. If a new high speed blower relay doesn't fix it, I have found a lot of times that it's the relay ground wire, that is just put under one of the relay mounting screws, often times won't be tight enough since taking the screws in and out of the fiberglass box takes the threads out of them. I usually lengthen the ground wire and bolt it to a solid metal ground.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
