![]() Join Date: Jul 2016
Switch Retaining nut & lock washer?
New wiper switch comes without, anyone know where to find as shown in this picture?
#2 | |
The Older Generation
Re: Switch Retaining nut & lock washer?
PM me your mailing address and I will send you a pair.... Freebie LockDoc
You got it Leon, and thank you in advance.
R/ DJ |
Leon,
I got your package in mail today. Not to be unappreciative, but you sent the headlight switch retaining nut & washer, not the wiper switch nut. I have a new wiper switch without nut and was looking for a replacement. Old is pretty chewed-up and wanted a second to use with manual choke cable. (Picture was example.) I am willing to pay for them, at least shipment, (have PayPal). My humble apologies for any misunderstanding. R/ Dave |
![]() Join Date: Dec 2013
Ace hardware !
![]() 1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
#6 | |
Brain Fa%t... That's what happens when you get old.. ![]() LockDoc
Leon,
I totally understand misunderstanding. Can I help pay for these? I seriously OWE YOU!!! I did try both ACE and BEST Hardware stores local and they do not carry the internal lock washer big enough or jam nut thin enough (9/16). And closest jam nut 1/2 by 20 (fine) thread, I would have to cut in half for thickness. I don't understand why you can buy the switch (from various parts places online, etc...,) but switches do not come with nut and washer, or at least have available to purchase?! R/ DJ Baar yes that is my nickname (both initials and name), Southern drawl on bear ![]() |
#8 | |
I mailed out the wiper switch washer and nut this morning. They will be in a small White letter envelope. It only cost $.46 to mail them.... Just hang onto the light switch stuff and send them to someone else that needs them.... LockDoc
Thank you again Leon. I promise to share the good karma and let you know when I get the other nut & washer.
R/ DJ |
Gut the wiper motor switch nut & lock washer from you in mail today. THANK YOU THANK YOU THANK YOU.
PS. Where do you recommend getting the correct tool to remove the ignition switch bezel? What I got from Truck Shop is WAY too big. Offset about 1/8 of an inch and their Customer Service said I may have to bend over tool tabs some to fit. Does that make sense? Thank you again Leon - you are a BIG help! |
![]() Join Date: Dec 2012
I believe you can span the two notches with a pair of needle nose pliers and twist off - at least I think I did that.
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop |
#12 | |
No problem. Glad they made it OK. I made a tool for removing the switch bezels out of a piece of thin wall tubing that just fit inside the bezel. I just made cuts in the tubing that matched the notches and bent the little tabs out to fit in them. It works OK if they are not real tight. If the one you bought is too big I don't know how bending anything is going to help.... LockDoc
#13 |
Roger that Leon & Ned. I have used needle nose pliers before too. I just thought since there was a "tool" and I was doing all that work with the dash..., I would just get the right "tool" since not too expensive. Didn't quite expect I was buying a "homemade" thing that wouldn't work and then get excuses and money back IF I paid for and shipped it back. A life lesson I guess - Ha.
Thank you again Leon for the nut and washer - makes for a quality install. ![]() |
