08-02-2016, 12:47 AM | #1 |
Wire harness pass-thru
Hey Everyone,
Finishing up installing my TPI into my dads 1965 C10(family hot rod!). I am now onto wiring harness. I used the stock wiring harness from a 1991 chevy Camaro, and as such it is very long. I was thinking about bringing it along the passenger side frame rail and then punching a hole under the seat, mounting the ecm there. What I am looking for is: passthrough options. I want something waterproof because the hot rod does get driven in the rain occasionally. Alternatively I was thinking about running the harness into the old clutch hole, but that exposes the harness and I am going for the hidden wire look here Thoughts? Other Suggestions? Feedback of some kind? Thanks! Scoutcamper |
08-02-2016, 08:08 AM | #2 |
Re: Wire harness pass-thru
I just posted similar info on the Correct Factory Restoration thread.
Our trucks cam with a area to transition the wires from the cab to the frame. Rear cab drivers side., do you have this ?
http://s1299.photobucket.com/user/jb...23904108567829 |
08-02-2016, 08:20 AM | #3 |
I made 2 piece aluminum to go around a brake rod boot. Copied from Mark" Crash OK" and mcbassin..some other good idea's here not the same year truck. http://67-72chevytrucks.com/vboard/s...494599&page=27 post #673 and #679 Also saw this, amazing setup. http://67-72chevytrucks.com/vboard/s...ewall+grommett
http://67-72chevytrucks.com/vboard/s...d.php?t=635605 |
08-02-2016, 01:32 PM | #4 |
The boat vent is a neat idea! I also see the grommet and RTV method but I would like to 1 day be able to remove this harness in tact if I ever upgrade or change things...
08-03-2016, 01:20 AM | #5 |
60-66 Nut
08-03-2016, 05:39 PM | #6 | |
