Old 08-02-2016, 03:59 PM   #1
55chiefdoug
Pulled the trigger on the 55- TF no chassis truck
I decided to go ahead and move forward (this weekend) on the 55 TF SWB truck. It comes with no chassis/frame (it is just sitting on the frame below) and it comes with a 59 cab and doors and doors for extra parts. The bed is one piece fiberglass. I have him below $3K right now, any thoughts?
I have a c10 donor for frame. I was thinking the ez chassis swap kit, 2 wheel drive with lowered suspension.
55chiefdoug is offline   Reply With Quote
Old 08-02-2016, 05:09 PM   #2
OrrieG
OrrieG's Avatar
Re: Pulled the trigger on the 55- TF no chassis truck
58-59 cabs are different from 55-57 in the firewall area (hood and clip mounting). Front clip items are different too. Doors are the same. Interior stuff is the same.
OrrieG is offline   Reply With Quote
Old 08-02-2016, 05:28 PM   #3
55chiefdoug
he wants it all gone and said there are some wiper parts and "other" items in the 59 cab that I may be able to use on the 55. I will need the glass out of the 59 doors
Old 08-02-2016, 06:07 PM   #4
lynx5653
lynx5653's Avatar
looks like a good start and the c10 chassis should work fine especially with ez chassis kit
1955 2nd on 86 chassis
Daily driver
lynx5653 is offline   Reply With Quote
Old 08-02-2016, 09:47 PM   #5
mr48chev
mr48chev's Avatar
If that sheet metal is as solid as it looks in the photos I'd say go for it.
I've told the story before but when I bought my 48 in 1973 the truck I really wanted bad was a 55/56 big window shortbed. I probably never will own one now but they are still one of my favorite trucks.
As far as the chassis goes it's your truck and your money and as it sits the truck has no chassis so head
My ongoing truck projects:
Old 08-03-2016, 07:49 AM   #6
55chiefdoug
lynx5653 do you have experience with the ez chassis kit?
I see mixed reviews but can't get anyone who has actually used it- good or bad, to respond to me.
Old 08-03-2016, 02:08 PM   #7
lynx5653
lynx5653's Avatar
no I have not used it but from what I have read and seen it seems to a good quality kit and I will be using on my 55 and my 58. Sorry I couldn't be more help
Daily driver
Old 08-11-2016, 10:26 AM   #8
dsraven
is the front clip all welded together across the front?
personally, I prefer the lower style of truck compared to the tall 4x4 look but hey, thats why it is called hotrodding, you do what YOU like and everybody else either likes it or keeps walking.
if you decide to put a different frame under the truck you may consider fabbing one up, they are really pretty flat with a dip in the front and a bump over the rear wheels. if you look at some of the things guys have done to their stock frame it is really only the original centre section of the frame that is left being used when done with the front clip replacement and the big c notch rear section. might as well have just started over if you know a welder or are good at welding and have a place to work. google images for 58 apache frame measurements for an image of a stock frame and you will see they are pretty flat. you could use rectangular tubing and install a mustangII front end or whatever you want up front. vary the width dimension to line up perfectly with whatever front clip you want, then build rear suspension accordingly. cab mounts and crossmembers would be easy to build as well.
