Old 08-03-2016, 11:48 AM   #1
waters5
1974 C10 Front brake Pads Rattle.. Help
I have a rattle coming from the front brake pads sounds like the pads are loose and slapping around in the Caliper. the noise goes away soon as little pressure is applied to the breaks. i have taken the pads out, replaced anti rattle spring on the inner pad. i think the outer pads are the ones making all the noise. cant find a way to fix issue or find any forums with a fix to similar issues. about to replace pads and anti rattle spring this weekend. any suggestions or help will be greatly appreciated before i start replacing everything
waters5 is offline   Reply With Quote
Old 08-03-2016, 02:16 PM   #2
friscobob
Re: 1974 C10 Front brake Pads Rattle.. Help
The calipers slide sideways on pins, make sure they are free to move, residual pressure valves should keep the pad "in touch" with the disks. Maybe the disks are warped and push the pads back or the wheel bearing have some slack in the and let the disks wobble around moving the pads back. Just some thoughts.
Bob
friscobob is offline   Reply With Quote
Old 08-03-2016, 03:49 PM   #3
nonstop
Did you bend the ears on the outer pads?
nonstop is offline   Reply With Quote
Old 08-15-2016, 04:06 PM   #4
waters5
Okay so i figure out the issue the outer pad ears were bent outward causing alot of play to resolve this issue i just picked up new pads and put them in with new Rattle springs the noise is no longer there nice and quite. i could of use the old pads and probably bent the ears down but i figure just replace it and forget it
anti-rattle, brakes, noisy brakes
