08-03-2016, 05:43 PM | #1 |
292 exhaust manifold Help!
Hello all, new to the forum and I have a question regarding my 64 c30.
I'm trying to locate a exhaust manifold for my 292 and have read mixed things on fitment. I looked at one from summit but it says it will not fit a 64!? I've located a used one from a 68 292 but am hesitant to get it without knowing it will fit for sure. Common sense would tell me most inline 6s would interchange. So I guess my question is: will any year 292 manifold work or is there something special with the 64? Thanks! Oh here's the truck I got it at a auction for 600 bucks! |
08-03-2016, 05:48 PM | #2 |
Re: 292 exhaust manifold Help!
For what it's worth, my 292 is a GM crate motor and I'm running my old 250 intake and exhaust manifolds on it. Everything bolted right up with no problems.
08-03-2016, 08:37 PM | #3 |
I have an extra one that will fit on the 292. Just pay for the shipping
08-03-2016, 08:55 PM | #4 |
Post Whore
They are all the same until they went with the integrated heads.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
08-03-2016, 09:49 PM | #5 | ||
Thanks guys. |
08-03-2016, 09:57 PM | #6 |
Never Ending Projects
From everything I know, the standard head is basically the same, it's the block that is different for the 292 and the smaller CI engines.
. 1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
08-03-2016, 11:35 PM | #7 |
Post Whore
All 292 parts are interchangeable between each other up until they used the integrated head and I believe water pumps differed through the years for them. 250's shared the same head and exhaust manifolds, but had a smaller intake like the 230. Heads are the same on the 230-250-292 and so are the bores, but the strokes are different. The 250 is a stroked 230 and the 292 is a taller block due to the rather long 4.125 inch stroke.
08-04-2016, 12:56 PM | #8 |
The 292 engines in the med. duty trucks (1 1/2 ton up) had a larger ex. outlet & it pointed straight down. The 1 ton & smaller interchanged with the 250 ex. manifolds although there are some minor differences. Some where around 71 they switched to a 3 bolt flange. Either will work if you change the flange on the exhaust pipe. I always tried to use 250-230 manifolds if you use used ones. The ex. on 292 engines run very hot & generally are warped or cracked.
