Old 08-03-2016, 08:49 PM   #1
tkeduk8r
tkeduk8r's Avatar
Looking for vendor and part number for 68 250 valve cover breather grommetlike
Like the title says, I need the oversize 1inch inside diameter breather grommet for my 68 stepper. Apparently this is an oversize compared to the 69 and later .750 id grommet. This is for the breather hose that connects to the 3" tall spacer between carb and air cleaner.... thanks in advance...
Mike
63 C20 2WD, 230/SM420/4.11 73K
68 C30 dump truck, 327,SM425,4.56 66K original
68 C10 2WD SWB Stepper, 250/3-tree/3.73 66K.... Wifes
68 Buick Skylark Custom Conv., 350/TH400/2.56 In our family since '79
69 GMC 1500 SWB 2WD, 350/TH350/3.73 posi...
70 K10 SWB 4X4 4-sp,ps, pb, tilt, buckets, console, sliding back window (Need AC parts) WIP
72 Chevy K20 4x4 350/350/205/4.56 donor
72 Vette 350/M21/3.70 posi, triple black and super fast
84 Olds Cutlass Brougham 350/2004r/4.11 was Dad's
tkeduk8r is offline   Reply With Quote
Old 08-03-2016, 08:54 PM   #2
swamp rat
swamp rat's Avatar
Re: Looking for vendor and part number for 68 250 valve cover breather grommetlike
I have seen 2 different sizes at auto parts stores on the little racks in the past, havent had to look for one in a while.
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 08-03-2016, 09:00 PM   #3
poway
Try this one. Mr. Gasket - #6375
poway is offline   Reply With Quote
Old 08-04-2016, 06:29 AM   #4
Shady Rascal
Shady Rascal's Avatar
The part numbers for the 1" ID, 1.5" OD breather grommet are as follows.
AIRTEX / WELLS 2P1002
STANDARD MOTOR PRODUCTS GV6
ACDELCO GR5005
If your parts store of choice can't help you, Rockauto has all three brands in stock.
Shady Rascal is offline   Reply With Quote
Old 08-05-2016, 12:13 AM   #5
CousinTone
Do you see it on this page anywhere? Let me know and I can provide GM Stock Number
CousinTone is offline   Reply With Quote
Old 08-07-2016, 10:45 AM   #6
tkeduk8r
tkeduk8r's Avatar
I think that grommet is listed in the pic.... and it's definitely not d-shaped as the deck, standard, and air Tex replacements are.... heres a pic... I erred in the I'd of the stamped hole as well...it's 1.187 or 1 3/16.... I can't believe a grommet can be this much of a pain to find 😠
Mike
Old 08-07-2016, 05:52 PM   #7
tkeduk8r
tkeduk8r's Avatar
Ttt
