Old 08-03-2016, 11:29 PM   #1
dragn91
dragn91's Avatar
K30 dually tire options. Anyone running humvee tires?
Just picked up a old beat to hell crew cab k30. I want to install a more aggressive tire on the truck before the dry rotted ones on it explode on me. I'm torn between buying a set of 255 85 16s for the truck or getting a set of humvee 37 inch tires. I have a set of 16.5 dodge steel wheels off a old camper, Would those work for that? If I run the military tires I think I can leave the drive train alone i think it's got 4.56s in it. If I run the 255 85 16s I think I will swap out the trans with an overdrive nv3500 or 4500 if I can find one to help on the highway a little maybe. If anyone is running a k30 with a more aggressive tire please post up some pics and info. . Google has failed me on the info part.
dragn91 is offline   Reply With Quote
Old 08-04-2016, 05:05 AM   #2
andrewmp6
Re: K30 dually tire options. Anyone running humvee tires?
The military 37s ride rough they are designed to handle the huge weight of a armored h1.
andrewmp6 is offline   Reply With Quote
Old 08-04-2016, 07:11 AM   #3
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
So I watch a guy on you tube with 37" hummer tires on a wrecker. search recovery solutions. he has a video of how he runs the set-up in the rear.
I don't think the dodge rims will work on the chevy axles. (I tried my son's 99 dodge steelies on a chevy dana60 and they rubbed the caliper)
The 37s on my 1983 are military tires, they ride ok.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 08-04-2016, 10:17 AM   #4
dragn91
dragn91's Avatar
Ok I'll look it up. There mid 70s dodge wheels so maybe they will fit. I'd probally run the humvee wheels up front anyway. I know they won't ride that great but the ride on a k30 isn't great anyway. I'd just run 255 85 16s if I could find them at a decent price. Is there a more common 16 inch tire that comes out around 33 -35 inches tall?
Old 08-04-2016, 10:35 AM   #5
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
285/75r16 is about 33" and I have a set of 315/70r16s that were on my k5 and measure around 35".
Old 08-04-2016, 02:15 PM   #6
83GMCK2500
I run a 255/86-16 on my dually and I needed a 1.5" spacer in the rear for comfortable clearance, just something to keep in mind. I've found the Cooper Discoverer ST MAXX to be an awesome tire and the 255 fits the (narrow) dually rim quite well. For your trans hunt don't even entertain the NV3500, it won't be nearly robust enough for a K30.
It's not a square, but check my build thread for my '96, page two will have some shots of the Coopers.
EDIT: 1.5" spacer.
Devin
1983 GMC High Sierra 2500, 4x4, RC/LB, 400 S.B., SM-465, NP-208, Corporate 10 bolt & 9.5" 14 bolt
1996 GMC Sierra SLE 3500 DRW, 4x4, EC/LB, Vortec 454, NV-4500, BW-4401, AAM 925 & AAM 1050
1997 GMC Sierra SLT 1500 4x4, Z71/F44, EC/SB, Vortec 350
My Introduction with my '83s History
New Daily, the '96
83GMCK2500 is offline   Reply With Quote
Old 08-04-2016, 09:47 PM   #7
dragn91
dragn91's Avatar
Damn I read that I could run the 255 85 16s without a spacer. If I have to run a spacer I'll prob just go with a little bigger slightly wider tire only because the seem to be a little cheaper. Is there any decent wheel spacers for less than 300 bucks? If I have to buy tires and spacers to get what I want maybe i'll just wait a bit and get the 20 inch monstir mayhems that I want. Those cooper's do look like an awsome tire I found some other 255 85 16s on tire rack I think it was like 1200 for all 6. And great job on that flatbed build was entirely expecting a complete cab swap.
Old 08-05-2016, 05:50 AM   #8
andrewmp6
https://www.youtube.com/user/recoveryteam
Old 08-05-2016, 09:32 AM   #9
83GMCK2500
Thank you, it's been a fun truck to own/drive/work on. I need to update my thread, last winter I warranty-exchanged the flatbed because the coating failed so thoroughly (side note: Bradford Built out of Washington, Kansas has fantastic customer service...I exchanged the entire bed for a new one at a local dealer) and last week I rolled over 300,000 miles.
What monster mayhems are you looking at? I've never heard of the brand before. I don't know what it was but before the 255 Coopers the Michelins I had on there were 235/85-16 and with anything less than 75psi THEY RUBBED! I guess there is a reason duallys have icky little 215s from the factory.
Spacers, I bought mine from Motorsport Tech (link), $275 w/shipping to me. They are awesome, solid steel and machined very well. A friend of mine pointed me in their direction after he got a set for his dually. He's running an old school set of Weld Aluma-dual IIs with a larger hub bore than GM, with his measurements Motorsport-tech was able to match that bore and now the old wheels are mounted in a hub centric fashion, he rolls down the road smooth as silk. He tows and hauls a camper on them regularly, no issues.
Wheel spacer porn:
Devin
New Daily, the '96
