Old 08-04-2016, 02:45 AM   #1
67chevy_hotrod
67chevy_hotrod's Avatar
Grinding sound... Ugh
1969 longhorn sb350/th400 eaton HO52 rearend. So if I accelerate hard I get a really bad grinding sound. (Sorta like a stuck starter). It runs fine and shifts fine when I drive normal. Last time it happened the shift linkage actually fell apart and I was stuck in low 1 after fartin with it. It's pretty terrifying to hear ha! Please anyone with ideas let me know! Thanks in advance.
1967 Chevy CST 10
1969 Chevy C/20 Longhorn
1969 K10 Suburban
1972 Chevy Cheyenne Super 10 turned K30 (sold)
67chevy_hotrod is offline   Reply With Quote
Old 08-04-2016, 05:35 AM   #2
Coley
Coley's Avatar
Re: Grinding sound... Ugh
I would get underneath the truck and check every connection between your transmission and your differential Including:
All U-joints thoroughly
The hanger bearing....thoroughly
The transaction mount....thoroughly
Make sure your differential is fully and correctly in place ....no broken mounts or shackles etc
(...also check your engine mounts while you are at it)
This would allow you to use the very proven method of process of elimination in isolating the problem
Start there
All good
Coley
....for some men, there is experience, skill and effort....for the others...there is visa and UPS LOL
1966 Chevy 1/2 ton (Florida- Red/white)
1972 Chevy 1/2 ton (California- Blue/white)
2005 Chevy Silverado HD2500/Duramax
2000 Dodge Ram 1500
Coley is offline   Reply With Quote
Old 08-04-2016, 08:44 PM   #3
swamp rat
swamp rat's Avatar
Is the fan blade hitting the radiator??? bad engine mount and transmission mounts.....
See if it just makes the noise driving under load or if it happens at a stop with revving the engine. Also pop the hood and rev the engine to see if the engine is rocking to one side to check the engine mounts. I think this would account for your linkage mishap.
While your at it jack up the rear of the truck and rotate a wheel and listen for any grinding in the diff, drop one wheel and check again.
Lots of good advice above but i think his "transaction mount" meant "transmission mount" with the damn auto correct syndrome
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 08-04-2016, 09:52 PM   #4
snipescastle2
snipescastle2's Avatar
Talking Re: Grinding sound... Ugh
Motor mounts, man I broke a few in my day, and ate a few radiators too! Brought back some memories from high school (sorry,didn't mean to hijack your thread) carrier bearings/throw out bearings might be a cause also.
Ben
"Persistence is the twin sister of Excellence.one is a matter of quality,the other, a matter of time"
“Serious Black” my 1971 Short Bed Fleetside Sold to
an outstanding man in Lees Summit,Mo. “Gone, but by no means,Forgotten”
snipescastle2 is offline   Reply With Quote
Old 08-04-2016, 10:27 PM   #5
67chevy_hotrod
It's not fan hittin radiator.. It definitely sounds like a transmission problem.. I will look into the rearend as well. I recently replaced the pinion seal.. It shifts fine and sounds fine at idle and at higher rpm. Under load or when I give it the gas a little aggresive is when it does it. This is irritating ha
1967 Chevy CST 10
1969 K10 Suburban
Old 08-04-2016, 11:58 PM   #6
67chevy_hotrod
Ok so all mounts are secure and intact. There is no evidence of exterior grinding on any drivetrain components( no fresh metal no scoring marks). The fan is definitely not hitting the radiator. I have not spun the rearend yet because I have had no time will do tommorow. Not sure what the next step would be if I can't decipher what is creating the beautiful sound ha
1967 Chevy CST 10
1969 K10 Suburban
Old 08-05-2016, 11:05 PM   #7
70STOVEBOLT
70STOVEBOLT's Avatar
You've checked to make sure there is not a muffler or e shahs the pipe vibrating against the frame or a suspension component or axle?
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Power windows
Power Locks
Sniper EFI
2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear
70STOVEBOLT is online now   Reply With Quote
Old 08-06-2016, 10:25 AM   #8
slikside
slikside's Avatar
Did the noise begin right then, or shortly thereafter? Always consider recent changes, especially when they "sound like" they could definitely be related to your problem.
I've never replaced a pinion seal myself, but I know that when it all goes back together you need a new crush sleeve, and it has to torqued just right...
I'm not saying it wasn't done right, just that it (or something related) could be the cause, since it was recently changed...
1972 Chevy C-10, SWB, Fleet, 350/350, PS, PB, HEI, mostly stock, Survivor.
slikside is offline   Reply With Quote
Old 08-06-2016, 10:44 AM   #9
midniteblues
midniteblues's Avatar
Just a few thoughts here. Perhaps it's the dust/inspection cover for the flex plate/torque-verter rubbing.
You could try duplicating the noise by setting e brake and pushing on the brake while giving it some throttle.
That might eliminate the road noise for better pin pointing where it's coming from.
81 camaro 355 4/spd 342 posi my first love.
67 swb step 454/4spd ott 373 posi 4/7 drop.
2000 s10 zr2 little blue truck that never gets stuck.
'74 heald super bronc vt8. tecumseh powered moon rover.
midniteblues is offline   Reply With Quote
Old 08-07-2016, 09:00 PM   #10
67chevy_hotrod
Lol brakes went bad today so that's been my immediate issue
1967 Chevy CST 10
1969 K10 Suburban
