08-04-2016, 08:46 AM | #1 |
Top of Dash
The top of my dash, cardboard part where the defroster vents are needs attention. In all the catalogs I have I havn't seen any listed. I'm sure these were painted with a flat or matt finish in regards to the glare from the sun. Is it possible to remove it from the truck without pulling the windshield? Maybe just pulling the dash pad and inside moldings?
08-04-2016, 09:12 AM | #2 |
Re: Top of Dash
Cardboard part?
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Sliding Rear Window Power Windows Power Locks Sniper EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear |
08-04-2016, 09:15 AM | #3 |
Re: Top of Dash
wondering if he means the insulator pads on the firewall?
Ben
"Persistence is the twin sister of Excellence.one is a matter of quality,the other, a matter of time" “Serious Black” my 1971 Short Bed Fleetside Sold to an outstanding man in Lees Summit,Mo. “Gone, but by no means,Forgotten” |
08-04-2016, 09:51 AM | #4 |
Re: Top of Dash
hello old51sedan.Top off dash where defrost outlets are is metal.If yours appears to be cardboard maybe a past owner fitted a piece of material there.If you remove your dashpad you will be down to the metal that runs up to the window.a good lite sanding and a good tape job and you are good to go.....a good flat black spray will do the trick.hope there is no ugly holes under the cardboard if there is a piece of it. remember no cardboard on top of dash ever....unless previous owner installed for some reason.......satin works also..but I hate glare...little bit of glare with satin I have found......Rob..
08-04-2016, 03:48 PM | #5 |
Florida Edition
Re: Top of Dash
As said, no cardboard. dash is steel. And just to add to the conversation I painted my dash gloss body color and wet sanded the shine down, looks great, reflection but no glare. Did the same with the defrost vents.
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod 67 C-20 Slant Back Wrecker "Mad Max" 67 C-10 Ratrod "Step-N-Wolf" 71 Serro Scotty Sportsman camper "Scotty" 97 LT1 Z28 "The Hornet" Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684 Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394 |
08-04-2016, 04:06 PM | #6 |
Re: Top of Dash
Thanks for the replies. I guess it's time I tore it apart to see what is going on. I've got a new column on the way that needs painting so it sounds like a good time to do something with the top of the dash also.
