Old 08-04-2016, 01:55 PM   #1
The Rocknrod
Moderator
The Rocknrod's Avatar
Rear Axle Seal Help
I'm putting a 5 lug rear axles, differential etc in the rear end of my 1964 C10 WC housing, 2wd. It seems the axle seals don't go in properly and stay in.
I had to use a seal puller when I removed the original 17 spline seals.
Anyone know if the 64 had a one off axle seal?
Seems like the area the seal sits in is cone shaped. . .
Old 08-04-2016, 07:48 PM   #2
Z POPPY
Re: Rear Axle Seal Help
The GM 12 bolt differentials started in 1964 until they we replaced by 10 bolts in the 1980's. All the 12 bolts were the same on bearings and seals except for the starting year. The 1964 had a taper different axle seal. Try this part number Timkin 8477s. This is for the coil suspension differential. Double check in the parts book can't check right now on vacation. Good luck Poppy
Z POPPY is offline   Reply With Quote
Old 08-04-2016, 08:08 PM   #3
The Rocknrod
Moderator
Thank you for the information. Learn something every day.
Old 08-04-2016, 09:22 PM   #4
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
12 bolt truck diff started in 63! Something else new to learn.
Old 08-05-2016, 01:07 AM   #5
Captainfab
60-66 Nut
The GM truck 12 bolt was used in the C10's from '63-'82. The '63 12 bolt had pressed on backing plates. I believe the '63 and '64 12 bolt used a different axle bearing and seal than the '65+.
Old 08-05-2016, 06:44 AM   #6
The Rocknrod
Moderator
Thanks Captainfab.
