Old 08-04-2016, 04:37 PM   #1
56 Woody
1956 GMC Steering column help
Thanks for all your help previously. I am at the point of buying a tilt column and would like to know what length it should be? I am putting a keyed tilt with automatic in it. I was going to put a 30 inch one in but wondered what about the linkage for the auto trans and how it will fit. I also need the linkage , any good advice please.
BW
56 Woody is offline   Reply With Quote
Old 08-04-2016, 04:45 PM   #2
dwcsr
Hollister Road Co.
dwcsr's Avatar
Re: 1956 GMC Steering column help
BW
it depends on your manifolds, trans type and any other issues in the path but typically 32" is the standard column for 47-59
dwcsr is offline   Reply With Quote
Old 08-04-2016, 06:19 PM   #3
56 Woody
I have headers and an automatic trans. It will have power steering and air conditioning. It has a TCI mustang front end under it with springs over shocks and the power rack system. I think that is all around that area.
So if I go with a 32 inch one I should be OK?
Old 08-04-2016, 07:20 PM   #4
OrrieG
OrrieG's Avatar
32 seems to be standard, but will depend on the steering wheel you use (flat or dish). Use a piece of 2" pvc and mock it up.
OrrieG is offline   Reply With Quote
Old 08-04-2016, 07:41 PM   #5
ChuckDriver
A320 Pilot/USAF Retired
ChuckDriver's Avatar
I put a cut down Chevy van column in mine, no key.
ChuckDriver is offline   Reply With Quote
Old 08-04-2016, 10:44 PM   #6
56 Woody
Thanks very much for the pictures ,it helps allot! So what I am looking at is a 28 inch column and it shifts a 700r4 trans correct?
Old 08-05-2016, 11:31 PM   #7
ChuckDriver
Worked perfect for me with the truck dash, it is a little tight now with the Impala dash.
