Old 10-04-2003, 09:50 PM   #1
LeRoy
Registered truck nut
LeRoy's Avatar
65 frame/front 72 disc brake/steering questions?
I'm putting a 72 front crossmember complete with all 72 steering linkage ect. into my 65? Short 2wd frame.
Questions:
-I noticed that the rod that hangs off the passenger side frame and attaches to the steering linkage is bent differently/more of an angle then the original one. What's the name of this rod for future reference? Should I drill a new upper hole or put the original back on. I'm not sure why they are bent differently. Does it have to do with the 3/8" dimples that were on the 72 frame attachment points?
-When putting on the 72 Power steering box. Can I just use some 3/8" flat stock to compensate for the 65 not have the dimples to clear the steering box? Then simply drill 2 new holes.
Thanks in advance
MOUNT VERNON, WASH. STATE
Need a part? Just PM me
LeRoy is offline   Reply With Quote
Old 10-04-2003, 10:39 PM   #2
our64
http://public.fotki.com/street
our64's Avatar
I think what you are talking about is the DRAG LINK. I used all the components from a 71 on my 64 short box. I did use the 71 drag link and very carefully re drilled the holes in the frame for that one. I had the ols fram from the 71 for reference. I have had the front end aligned and there were no problems. I can send you a photo tomorrow if you like
our64 is offline   Reply With Quote
Old 10-04-2003, 10:46 PM   #3
LeRoy
LeRoy's Avatar
Thanks for the reply. I'd much appreciate those pics
Old 10-06-2003, 10:13 AM   #4
our64
our64's Avatar
Drag Link pictures
Here is my stock 64 cross member with all the steering components,disc brakes etc from a 71. I think if I did it again I would have switched the whole cross member. The angle and position I drilled the frame I took off the 71 frame. Good Luck. I don,t think it matters but I still have the manual box on ,but will be putting the power steering box on soon
Old 10-06-2003, 04:33 PM   #5
LeRoy
LeRoy's Avatar
You used washers to space it out. How far is it spaced. I'm thinking about 3/8"
Old 10-06-2003, 08:08 PM   #6
our64
our64's Avatar
Sorry..Yeah your right. I think I used thick wall tubing and cut spacers the same hieght as the dimples. Im sure washers would do too, I just think a spacer looks better..Good luck, hope the picture helped
Old 10-25-2003, 02:20 PM   #7
65' sleeper
I used my stock drag link. I did not do a whole crossmember swap, but I am using a 71' power steering box and all 71' disc brake components. Everything lines up perfectly. It may be different if you have the 71' crossmember, but I have never heard of anyone having to change the drag link. Have you tried just using your stock one?
65' sleeper is offline   Reply With Quote
Old 11-01-2003, 03:00 AM   #8
LeRoy
LeRoy's Avatar
I'm going to check it out. I've got both setups and would rather not have to drill any holes
