08-05-2016, 10:50 PM | #1 |
Underhood treatment.
How do you fellows treat the underhood? Insulation, plain paint, bed liner, let-er look bad?
Bob |
08-05-2016, 11:02 PM | #2 |
Post Whore
Re: Underhood treatment.
You talking about the bottomside of the hood?..if you are what I did was paint mine and put in a new ebay hood insulating pad..
08-06-2016, 12:54 AM | #3 |
Painted mine satin black. Simple and sweet
Chris _______________________________ 1979 Chevy Stepside SPORT 2018 Chevy Silverado, 39 years apart My build 2008-2016. http://m.imgur.com/a/bURrE |
08-06-2016, 01:01 PM | #4 |
Just here to tinker
I prefer to keep the insulation. It keeps the noise down.
78 C10 SWB Diesel #1 (wrecked)http://67-72chevytrucks.com/vboard/s...1978+silverado 78 C10 SWB Diesel #2 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=650751 60 GMC Suburban (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=445526 60 GMC 1000 (sold)http://67-72chevytrucks.com/vboard/showthread.php?t=298235 67 GMC 1500 (sold) http://67-72chevytrucks.com/vboard/s...d.php?t=803695 73 Chevy C20(Daily)http://67-72chevytrucks.com/vboard/s...d.php?t=852767 86 Suburban(summer unit) http://67-72chevytrucks.com/vboard/s...d.php?t=810697 88 Suburban 4x4(sold) |
08-06-2016, 04:26 PM | #5 |
I painted the entire sheet metal under the hood, including the hood underside, with gloss black paint from Home Depot ($1 per rattle can.) It looks ok to me, except on one inner fender where a gust of wind blew dirt in that location when the paint was still wet.
I got underhood fiberglass insulation pad from LMC and was able to reuse the original plastic push pins. I would not use that again LMC pad again. I would use any of the better aftermarket insulating materials and use that, like heat resistant hood insulation. That aftermarket insulation is pricey, but I don't think the LMC stuff does any good, at least is does not deaden the engine noise in my experience. |
08-07-2016, 06:02 PM | #6 |
Anyone got a pic of OEM insulation on an 81 and up? Thanks
Bob |
08-08-2016, 08:21 AM | #7 |
Heres my 82 . This came from the dealership . It comes as one big sheet . You will have to trim it to fit . The clips also come from them and are in the factory locations . I made a cardboard pattern to trim by . Heres a couple pictures .
08-08-2016, 10:02 AM | #8 |
Thanks, last time I dropped by the Chevy dealer the parts "kid" just stared at me, an 81? My truck was older than he was, he didn't even know that Chevy had built an inline 6 cylinder. I'll try em again. I already have the plastic push pins, found a good source too. Could you tell the difference when you put in the insulation?
Thanks, Bob |
08-08-2016, 10:16 AM | #9 |
I had seen some aftermarket stuff and was not impressed and is why I got the dealer stuff . I dont think the gm stuff was year specific . It was just a generic sheet that gm offers to trim and fit . Also it was not folded like you would get aftermarket . If you fold this kind of stuff it will create a permanent seam in it . It is in a large box because it is not folded . I did like the quality better . Also it had some rigidness to it .
08-08-2016, 05:30 PM | #10 |
That fiberglass insulation is the same stuff I got from LMC.
08-08-2016, 07:09 PM | #11 |
Post Whore
I used this and am happy with it...it did quiten down engine noise some.http://www.ebay.com/itm/1981-1982-19...RXcbw4&vxp=mtr
08-09-2016, 04:22 PM | #12 |
Mine with a layer of FatMat in between.
08-09-2016, 04:47 PM | #13 |
Frequent Flyer
Here is what I used on mine... http://www.quietride.com/acoustihood.html
It comes with heat insulation you put in all the indentations on the bottom of the hood before you put the ABS panel on. |
08-10-2016, 07:30 AM | #14 |
^^I have the same kit.^^
