1960 pan hard bar
I have a 1960 suburban and I know the bar is longer, then the 63 to 72 but does anyone know if the mount on the trailer arm is different also the kit I have the angles just do not seam right??
Re: 1960 pan hard bar
The bar does not go to the trailing arm, it goes to the top side of the axle. And it looks like the bushings are too fat and spreading the factory mount. The kit that goes to trailing arm is not for 60-62 I believe. Mine from Porterbuilt is behind factory.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats http://www.cardomain.com/ride/332579...t-c-k-pick-up/ http://67-72chevytrucks.com/vboard/s...d.php?t=560081 Last edited by LVPhotos; 08-06-2016 at 09:54 AM. |
this is the bar I have, it mounts to the frame and a bracket on the trailing arm. the angles are just slightly off mine Is a 60 and I think the bracket that mounts on the trailing arm might be different for the 60 to 62 then the 63 to 72?
I would say the bar is in bass-ac-wards
