Not too old to learn
Clutch versis fixed fan
I'm running a new 290 HP 350 Crate .
The truck is a C10 turbo 400. General use is daily for light home hauling items nothing heavy, trailer or sand or concrete bags. mostly a grocery getter and fun to drive. Now have a clutch fan in it, that is failing, grease coming out around front of housing. Temperature climbs on hot days more noticable in heavy slow traffic. Should I just use a stock fixed blade or spring for another clutch fan ? SoCal do gets hot in the summer...... 95 plus every day.
1968 C10 a way to long restoration. |
Re: Clutch versis fixed fan
You want the big 7-blade fan, but you don't want to run that fixed, so I'd replace the clutch. Much better than a fixed 4 or 5 blade, I think.
All about them K’s
![]() Join Date: Jun 2014
Those fixed blade fans can be pretty dangerous too. Ever see one go thru a hood?
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 ![]() |
#4 | |
20' Daredevil (Ret)
![]() Join Date: May 2003
While I'm not aware of any issue with fixed-blade fans going through the hood (now a flex fan is a different matter), they make noise and rob power all the time, and still cannot pull nearly as much air as an engaged clutch fan.
#5 | |
All about them K’s
OK, I got it.
Just was looking for options.The truck already has a 7 blade with a clutch. So this is easy , just get a new clutch....some times I'm a dumb ass. ![]() ![]() Thanks all.
