Hazard lights/flarestat 105 problems
I installed a flarestat 105 on my '63 that I got on ebay. So far the light (on the knob) comes on and the front passenger flashes. I connected the flarestate wires to yellow, green, light blue and dark blue on the steering column harness. It should work according to the diagram found here:
http://6066gmcguy.com/turnlights1.html All the signals work otherwise. Should I start troubleshooting the switch? or did I wire it wrong? |
Re: Hazard lights/flarestat 105 problems
I would open up the switch check all contacts and clean and lube
Will do thanks!
![]() Join Date: Jun 2015
How many wires does your flarestat have coming out? Mine has 9 wires coming from it, and I'm trying to figure out what they all mean.
1961 GMC half ton, short step, Canadian model. Just starting work on it. |
I have 5 wires. 4 for each side and one for power. The wire colors on the switch are random. Black, red, brown etc. But the wire for power already had a fuse and is connected to a flasher.
Not sure if it helps but I did some testing and it turns out the green wire is for the horn so I unplugged that (flarestat) wire and moved it to orange (I think that's the rear drive's side)
