08-06-2016, 10:58 PM | #1 |
Carb selection
74 C10 350 w/Carter Quadrajet carb. Not satisfied with gas milage, around 9 to 11 mpg. Carb may need rebuilt. Mulling over whether to rebuild or get a 600 cfm Edelbrock. Are there any suggestions?
TIA
1974 Cheyenne 10 LWB Stock 350 W/HEI /TH350/AC/4 BBL Quadrajet Mopar by Birth Chevy by Choice |
08-07-2016, 09:08 AM | #2 |
Re: Carb selection
Probably not the best move for mileage. You'll need to adapt an eddy to your intake. You'll spend a few hundred and likely get the same or worse mileage!
Tune the wazoo out of what you got first!! What's your timing curve like? |
08-07-2016, 09:27 AM | #3 |
Robert Olson Transport
Re: Carb selection
the best bet for mileage is having your quyadrajet rebuilt and the motor properly tuned my edelbrock 650 had a note on the box that its not meant for any kind of emissions standards in any state so if emissions are high I am sure mileage is low
08-07-2016, 09:45 AM | #4 |
Re: Carb selection
Without knowing your tire size, rear end ratio, or transmission info 3 or 4 speed. mileage doesn't sound that bad. IMO
Desert |
08-07-2016, 11:39 AM | #5 |
Re: Carb selection
I see the prices on throttle body injection is stating to come down, not sure if I can mention brand names or sources here.
08-07-2016, 02:36 PM | #6 |
Re: Carb selection
A properly setup Qjet is the best carb for a daily driver type of truck. Trick is finding someone that can do a good job.
+1 to Desert's comments on drive train. My 75 350/TH350 with 3.42 rear end gets between 12 and 14mpg highway depending on speed. Just over 12 @ 70, 14 around 60. Point distributor or HEI? Not sure of final year for points. |
