08-07-2016, 07:28 AM | #1 |
54 chevy truck fitting front fenders
I need some help adjusting front fenders,I can shim the fenders to get the correct gap to make them wide enough.But can't firure out how to raise them.
08-07-2016, 08:52 AM | #2 |
Re: 54 chevy truck fitting front fenders
08-07-2016, 09:36 AM | #3 |
Hollister Road Co.
08-07-2016, 11:16 AM | #4 |
This one shot isn't going to help much, we need photos with the fit of the entire front end.
Hood to cowl, really makes a difference to understand what we are seeing here. But at first glance here it looks like the front end is too high, the rad support is too high. See how the hood is hitting the grille at the very front? How can you raise the fenders with out raising that too, you can't. This is why you must trial fit everything before painting. Brian
1948 Chevy pickup Chopped, Sectioned, 1953 Corvette 235 powered. Once was even 401 Buick mid engined with the carburetor right between the seats! Bought with paper route money in 1973 when I was 15. "Fan of most anything that moves human beings" |
08-07-2016, 12:32 PM | #5 |
A couple more picturesQUOTE=MARTINSR;7676184]This one shot isn't going to help much, we need photos with the fit of the entire front end.
Hood to cowl, really makes a difference to understand what we are seeing here. But at first glance here it looks like the front end is too high, the rad support is too high. See how the hood is hitting the grille at the very front? How can you raise the fenders with out raising that too, you can't. This is why you must trial fit everything before painting. Brian[/QUOTE] Posted via Mobile Device |
08-07-2016, 12:34 PM | #6 | |
08-07-2016, 12:38 PM | #7 |
08-07-2016, 12:47 PM | #8 |
How about how the hood fits the cowl, you still haven't shown us that. Side view where the fender meets the cowl and at the top up by the vent, it is high there, is the gap closed up, these are all needed to help you.
Brian
08-07-2016, 12:52 PM | #9 |
Get level with the grille to show how high the hood is compared to the grille, get level with the top of the cowl to see how high hood is with the cowl.
Level with the fender to show how the hood fits with the fender and cowl. Brian
08-07-2016, 12:54 PM | #10 | |
That photo looks like the fenders are in too close together. But it could also be that the whole front, rad support fender assy is too far back. Being the hood and opening at a triangle shape if the hood is too far forward or the fenders are too far back, the "hole" the hood sits in gets closed up, get it? Brian
08-07-2016, 12:54 PM | #11 |
08-07-2016, 12:56 PM | #12 |
08-07-2016, 12:59 PM | #13 |
08-07-2016, 01:05 PM | #14 |
See how moving the triangle forward closes the gap?
And moving it back opens the gap? These fenders don't have much movement at all going out away from the hood, the way they bolt to the rad support and aprons doesn't allow for that. But moving them forward away from the cowl that gap grows. Brian
08-07-2016, 01:07 PM | #15 |
With the large gap at the back of the hood it looks like moving the hood back will help you quite a bit. But it will close up the gap more at the front of the fenders. It really looks like the fenders are high in the front, maybe too far forward too?
How is the rad support mounted to the frame? Is it stock or does it have a clip or different frame under it? Brian
08-07-2016, 01:09 PM | #16 |
Hollister Road Co.
close up this gap. your hood is in the correct position (level) because the gap is even top to bottom, it just need to go back so you have 1/8 gap. it will not hit the cowl when opening. then move the clip forward. you may need to shim up the front mount. it should all look ok then,
08-07-2016, 01:10 PM | #17 |
[triangle? QUOTE=dwcsr;7676287]close up this gap. your hood is in the correct position (level) because the gap is even top to bottom, it just need to go back so you have 1/8 gap. it will not hit the cowl when opening. then move the clip forward. you may need to shim up the front mount.[/QUOTE]
08-07-2016, 01:10 PM | #18 |
The holes in the cab and fenders are HUGE to allow for movement. If the fenders are all the way back at that point, that could be a big reason. It's so hard without seeing with our own eyes moving around getting a look at the whole thing.
But I am thinking that darn rad support is too high. Brian
08-07-2016, 01:12 PM | #19 |
Are these reproduction parts? You said the parts were trail fit, was the grille mounted at the time? Damn it is looking like more than a simple "fit" issue.
I am not awake yet apparently. Let's clarify, are they repro parts, is the rad support original, is it mounted as original on the original frame? Brian
1948 Chevy pickup Chopped, Sectioned, 1953 Corvette 235 powered. Once was even 401 Buick mid engined with the carburetor right between the seats! Bought with paper route money in 1973 when I was 15. "Fan of most anything that moves human beings" Last edited by MARTINSR; 08-07-2016 at 01:19 PM. |
08-07-2016, 01:17 PM | #20 | |
Thanks. I will give it a try
08-07-2016, 01:20 PM | #21 |
I am thinking about this too much....geeez
Yes, move the hood back and the gap along the sides will open. The problem is, if the fenders are too high then the hood will hit the grille before this can happen. Or of course if the grille hood or fenders are reproduction then all bets are off. All it takes is a tiny bit difference with the shape of the hood and it throws everything out of whack big time. Brian
08-07-2016, 01:23 PM | #22 |
There is a 1/2" plate of steel under the radiator support. Was there before painting. It will be easy to removePosted via Mobile Device
08-07-2016, 01:34 PM | #23 |
It sure seems like that would be a problem, but the hood going down in the front and moving it back will screw up the gap at the back.
The more I look at this it seems the upper grille bar is high in the middle. Geez, I need to shut up and let the other guys throw some stuff out there. I know one thing, sometimes panel fitting is a "dance" and trying to get all of it perfect is impossible, often you have to get an "ok" fit on one panel to get the "ok" fit on another which is a heck of a lot better than a perfect fit on one panel and a horrible fit on another. Moving the hood back and up a hair on the back, lowering the rad support too may be needed to get an "ok" fit everywhere. But I think if that happens the hood is going to hit the grille. This is why I am a big believer in jambing, assembling and painting together when being done at home for the typical guy. What you are doing is difficult for the experienced guy let alone if it's not your thing. Brian
08-07-2016, 01:37 PM | #24 |
[oem partsQUOTE=MARTINSR;7676295]Are these reproduction parts? You said the parts were trail fit, was the grille mounted at the time? Damn it is looking like more than a simple "fit" issue.
I am not awake yet apparently. Let's clarify, are they repro parts, is the rad support original, is it mounted as original on the original frame? Brian[/QUOTE] Posted via Mobile Device |
08-07-2016, 02:48 PM | #25 |
