Old 10-05-2003, 12:43 AM   #1
BLACK AND BLUE 67-72
Firefighter
BLACK AND BLUE 67-72's Avatar
Power Steering Box Rebuild
How hard to rebuild a power steering box? My pitman shaft splines are worn, so it lets my pitman arm slop around. Can I just replace the shaft if I have another old box? If so what all is involved with replacing the shaft? I hate to get rid of mine because it does not leak and I do not have the money for a new one.
'72 Chevy SWB 350 Auto
'67 GMC LWB 350 4 speed
'70 Chevy 4x4 Stepside 350 Auto
Yellville, Ar. USA
BLACK AND BLUE 67-72 is offline   Reply With Quote
Old 10-05-2003, 09:17 AM   #2
JimKshortstep4x4
Talking
You can replace your pitman shaft without too much difficulty. I have rebuilt boxes when they were out of the truck but I believe that there is enough clearance to remove the shaft with the box in the truck.
Anyway this is how I would do it. Remove the pitman arm, clean the pitman shaft thoroughly as it will be sliding through the seals. Lube the shaft with a good clean lube, (oil or light grease).
Make sure that you have drained the box before pulling the cover.
Center the steering, (go lock to lock count turns and then go 1/2 way back). Remove cover bolts and tap shaft out with a soft hammer, (lead or brass is what I use). If the shaft hits the housing on the way out turn the shaft to clear. The shaft and cover will come out as an assembly.
Hopefully you won't damage the shaft seal, but if you do it will have to be replaced.
Installing the other shaft should be easy, just make sure that it is clean.
Good luck!
Jim
Old 10-05-2003, 01:29 PM   #3
Firefighter
Thanks Jim!! I will have to try that!
Yellville, Ar. USA
Old 10-05-2003, 08:09 PM   #4
Spoof
Spoof's Avatar
Hi,
As I mentioned in another post Hot Rod covers the entire overhaul process in their Chevy-GMC Pickup Repair manual. Available from some vendors.
71 GMC 1500 LWB
Spoof is offline   Reply With Quote
