08-07-2016, 12:03 PM | #1 |
Fuel gauge wire to rear
Just put in a blazer tank in the rear in my 72 and m looking for ideas how everyone routed their fuel gauge wire to the rear. Mine comes off the fuse panel but I'm looking for a nice way to route it to the rear. Through the firewall to the rear?
Any suggestions? |
08-07-2016, 01:42 PM | #2 |
Re: Fuel gauge wire to rear
I'd run it through the fire wall along with the wires for the tail, brake, and back up lights. I ran those wires in that new style wire wrap that looks like those old Chinese finger torture things we played with when we were kids. It's made of a braided nylon and wraps in on itself for a very clean look. Look at Summit or Jegs under wiring looms.
08-07-2016, 08:13 PM | #3 |
Perfect I'll do that
08-08-2016, 08:54 AM | #4 |
In Canada we can bu that loom from any auto parts store. Pico carrys it.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
08-08-2016, 02:07 PM | #5 |
I need a tank soon. What year blazer tank did you use? How was it to install and route the filler tube? Any pictures of the install?
08-08-2016, 04:16 PM | #6 |
Hello-
I purchased the relocation kit and straps from classic industries. It wasnt that difficult to install. I ran the sending wire through a hole on the firewall down the frame rails and to the unit itself. I ran two 6' hard fuel lines from under the cab where they went to the factory tank Ive yet to install the fuel filler, but I plan on putting in the rear stake pocket. |
08-08-2016, 04:22 PM | #7 |
What year blazer tanks fit in a 72 c10? I have access to a couple but don't want to call in a favor if it won't fit. Thanks.
08-09-2016, 08:18 AM | #8 |
This is the one I bought.
http://www.classicindustries.com/pro...ts/cx5024.html You will need to modify your rear cross sill on your bed for this to fit. About 2- 2 1/2 inches or so. Then its about running your fuel lines and then deciding how you want to mount your fuel filler. There is a bed filler option as well if you dont want to route it to the the side. |
08-09-2016, 08:59 AM | #9 |
Great. Thanks a lot. I just need to figure out how I want to fill it. For those of you that have done it, can it be fill behind the license plate like on old cars?
08-09-2016, 11:45 AM | #10 |
Not with this tank. You would need a camaro tank to do that.
