08-07-2016, 04:46 PM | #1 |
Valve train Noise
08-07-2016, 04:50 PM | #2 |
Re: Valve train Noise
08-08-2016, 12:10 AM | #3 |
neither video works
WHO_DCTC - Wifes 05 Z-71 Build - Now defunct as she decided she wants an Escalade too Cream Puff - LS'd Square - Slow going on the back burner Tripple Threat - 3 Wrecks for the price of one build thread Project Delongdium - Step-Sons Plastic Clad 2003 Avalanche - DONE and Delivered. |
08-08-2016, 12:41 AM | #4 |
Post Whore
I can get it to play but the exhaust is so loud I can barely hear the valve noise but I can hear it..I wouldn't think I should hear it at all so I would say its excessive.
08-08-2016, 12:53 PM | #5 |
I've heard valve train noise on ls motors is common. This is my first ls motor so not sure how much noise is normal.
08-10-2016, 11:42 AM | #6 |
When you go high lift cam and heavier springs you will get valve noise. The only other thing to check is the pushrod backlash.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
08-10-2016, 05:16 PM | #7 |
meowMEOWmeowMEOW
If you recently switched to a header from a cast manifold, your actually hearing the valve events from the exhaust site of the head. The thin wall tubes are NOISY and you'll hear pingy-ticky noises which never used to be there.
If your valvetrain geo is actually off, it'll sound like your trying to turn over one of those old external pushrod engines...like a damn sewing plant from the 1930's.
08-10-2016, 05:36 PM | #8 |
I've always had long tubes on it. You can only hear it during a certain rpm and at idle
