Old 08-07-2016, 10:41 PM   #1
cgster
Oil Pressure Line Question
Installed a new 350 engine in my truck and the oil pressure line doesn't seem to fit anywhere on the engine or the hole is a different size. Is there an adapter or something I can use so I can still have my oil gauge work?
My original line:
cgster is offline   Reply With Quote
Old 08-07-2016, 11:20 PM   #2
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Re: Oil Pressure Line Question
That part of the fitting fits inside the fitting that screws into the back of the block. The one that fits in the block I believe is 1/8" NPT and that part at the end of the copper line fits in to that.
Don't start your new engine without anything in that hole in the rear of the block or you will have oil EVERYWHERE!
...ask me how I know...
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 08-07-2016, 11:23 PM   #3
71swb4x4
71swb4x4's Avatar
Here is an adapter: http://67-72chevytrucks.com/vboard/showthread.php?p
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 08-07-2016, 11:24 PM   #4
cgster
Originally Posted by 71swb4x4 View Post
Link sent me to an error page
Old 08-07-2016, 11:34 PM   #5
cgster
Gary
lol I found out the hard way myself....
Do you happen to have a link to the one that I would need? Thanks.
Old 08-07-2016, 11:38 PM   #6
71swb4x4
71swb4x4's Avatar
Try again: http://67-72chevytrucks.com/vboard/s....php?p=7455766
Edit: and from another of LockDoc's threads: "The male end is 1/8" pipe thread and the line fitting (compression sleeve nut) screws into the other end."
Old 08-07-2016, 11:39 PM   #7
Gromit
Here is a photo but this is not as good as SWB4x4 because I don't know the part number or where to buy.. Maybe Ace Hardware too; theirs are all non-lead fittings now and they are more expensive than the automotive versions that are still okay with lead content in the bronze...
If you have the dual dipstick block make sure your dipstick tube hole in the block (opposite of wherever you put the dipstick) is plugged with that little steel plug.. passenger side or drivers side..No offense I hope but I just have read about so many people missing that..
Gromit is offline   Reply With Quote
Old 08-07-2016, 11:42 PM   #8
cgster
Great, thanks!
Old 08-08-2016, 01:14 PM   #9
cleszkie
cleszkie's Avatar
Gary
I could have been worse! Once, I forgot to reattach that line to the back of my gauge. Oil everywhere INSIDE the truck
cleszkie is offline   Reply With Quote
Old 08-08-2016, 02:13 PM   #10
tommys72
tommys72's Avatar
Hmmm...i did that once too. Guess where the oil went? All over my brand new medium blue carpet....it took alot of scrubbung and different chemicals and even more cussing, but i got it all out finally
United States Marine Corps 2000-2011
Iraq and Afghanistan veteran
Just living life now and enjoying it and my wife, daughter and son
tommys72 is offline   Reply With Quote
Old 08-08-2016, 02:33 PM   #11
davepl
davepl's Avatar
I guess I'm not the first, second, or third to have accidentally run the truck without the gauge connected! I got lucky in that it landed on a floor mat, though.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 08-31-2020, 07:43 PM   #12
pjmoreland
pjmoreland's Avatar
I spent quite a bit of time last night searching through old posts trying to find information on the engine block adapter. I headed over to Napa today and they sell them. Their part number is 6200x2.
Male Connector - 1/8" Tube O.D., 1/8" Male Pipe Thread
https://www.napaonline.com/en/p/WH_6...rdInput=6200x2
pjmoreland is offline   Reply With Quote
Old 08-31-2020, 08:49 PM   #13
LockDoc
The Older Generation
LockDoc's Avatar
Here is a thread on it.
http://67-72chevytrucks.com/vboard/s...d.php?t=613238
LockDoc
Leon
Old 08-31-2020, 08:52 PM   #14
pjmoreland
pjmoreland's Avatar
Originally Posted by LockDoc View Post
Yes, I did see that thread last night, and I will be using your instructions on bending the tube. Thanks!
