Old 08-09-2016, 04:22 PM   #1
Low69CST
Factory Tach Won't Work
I had my truck together a few years ago and the tach worked fine. After a few years of sitting, my tach won't work. I have a painless wiring kit and a built 400 small block with a pertronix HEI. Everything appears to be hooked up fine. Is there anything simple I may be missing. It's possible someone may have took something apart and didn't put it back correctly. The wiring diagram has the purple/white wire going from the distributor to the tach. And I also have a yellow wire plugged into the tach. Does anyone have any ideas?
'69 CST Short fleetside
Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress)
'87 V10 4x4 Short Fleetside
Quad Suspension and Dual Tanks
Low69CST is offline   Reply With Quote
Old 08-10-2016, 01:59 AM   #2
HIGHWAY BY THE SEA
HIGHWAY BY THE SEA's Avatar
Re: Factory Tach Won't Work
Mine also stopped working mysteriously. I simply removed it from the truck and sent it to these people.
Willcox Corvette, Inc.
123 E. Maple Street*Jeffersonville,*indiana*47130*
800-588-3883
You may have to call and make sure they are willing to fix it. They typically work on Corvettes mostly, but occasionally they will work on these truck tachs as well. They are very friendly and very fast too. I got mine back in less than a week.
FRANKENTRUCK 1981 Chevrolet C10 Shortbed Stepside
GRANDTRUCK 1968 Chevrolet C10 Stepside Longbed
http://67-72chevytrucks.com/vboard/s...d.php?t=584617
PROJECT JIGSAW 1967 GMC C3500
GREAT WHITE 1986 Blazer M1009
HIGHWAY BY THE SEA is offline   Reply With Quote
Old 08-10-2016, 11:13 AM   #3
davepl
davepl's Avatar
Mine also did not work with a Pertronix module in a stock body distributor. So I swapped it for a repro that a friend had and that works, so it was hit or miss. I do know with the Pertronix the low-RPM reporting can be off because it does multiple spark, sometimes that will skew it to read higher than actual.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 08-10-2016, 12:39 PM   #4
FlounderGDI
FlounderGDI's Avatar
I just put a factory tach into my 69 CST-10... It's supposed to ground to the cluster tin but mine wasn't. I ran another ground from a screw under the dash and up to the grounding lug on the tach and mine started working. Maybe checking your grounds and cleaning them up might help.
1969 CST/10 "GreenAndWhite"
1974 Nova (SOLD... End of an Era)
2000 Impala (RIP)
2008 Malibu
Brand Loyal... I've never owned a Vehicle not made by Chevrolet.
FlounderGDI is offline   Reply With Quote
