A/C reached critical mass!
Stock setup on my big block. When the engine was out and rebuilt 4 years ago I replaced the expansion valve, eliminated the POA valve and installed a High Lo pressure switch, new receiver dryer, vacuumed and converted to 134a. Its always been ok but not great. Its been working for the past three years but cycled continuously at anything above idle. I decided that I would adjust the pressure switch. I upped the idle in park to try and duplicate the cycling; I'm guessing the head pressure reached a point that literally blew the manifold line right off the back of the compressor. I'm not sure why the A/C didn't cycle in park like it would with the vehicle moving? I'm open for opinions on the cycling and if I should just rip out the factory setup and go with vintage air? I don't even know if I can just bolt the hose back on the back of the compressor? I think it (hose with the manifold) is held on by a single bolt in the center but I've not found the bolt since the explosion.
1971 Longbed BB Cheyenne Super 1972 Longbed SB Cheyenne Super 1972 Longbed Highlander Custom Deluxe 1975 K5 4x4 full convertible Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=645165 Greg Smyrna TN |
Re: A/C reached critical mass!
I wouldn't replace the whole system just because something is wrong with it, that's an expensive troubleshooting approach!
I don't know anything about removing the POA, but when not leaking mine works fine with all stock components except a parallel-flow condenser.
I would recommend putting a POA valve back on it since that is how the system was designed to work originally. (It needs to be adjusted to work properly with R134.) I'm not a big fan of the POA eliminator setup. Replace the drier, all the o rings, flush the system, and evacuate and charge the system properly and you should be good to go.
"Negative people always seem to have a problem for every solution" |
Id go back to a poa valve recalibrated for 134a. Its easier on the A6 compressor which wasn't designed to cycle. And replace the factory tube and fine condenser with a parallel flow condenser. Those are the two issues that a lot of people don't do when converting to 134a
Moderator
![]() Join Date: May 2007
I would keep the factory system and put the POA back. Then go back to R-12 which is what the system was designed for and enjoy a "fantastic" system that blows snow no matter how hot it is, instead of an "ok" system with problems.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
That is actually the simplest thing to do also. r12 can be had on CL, swap meets and ebay. Its not really that expensive either.
#7 | |
Moderator
The POA is designed and installed to prevent freeze ups in the evaporator. Without one in the system, your compressor should have been working full speed at all times and the car should have been ice cold without any way to "throttle " the cooling.
The pressures of R12 and R 134a are fairly close. Why didn't the high pressure switch shut the compressor off? Is the condenser dirty? While idling there couldn't have been perfect airflow. Can you show a picture of where the leak occurred? It's possible that there was air/non condensables in the system that caused the pressure spike I would install a POA, change dryer, and pressurize with nitrogen before evacuating and installing R134a. |
Old member
I'm going the other direction. Put a acumaltor in it and new hoses and 134a and never look back.
This is a older picture but it shows the system. Over 20 years with no problems operating. ![]() ![]()
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
Thanks for the responses everyone. The system has worked as configured for the past 3 years, just cycled continuously at anything above idle. IMO the reason the thing was cycling was that the pressure was going too high and the switch was doing what it was supposed to do. I screwed up by shorting across the pressure switch so that I could adjust the set screw. By shorting across the switch I actually prevented the switch from working and when I got to about 2K RPM's, BOOM, it blew the line off. So if in fact the pressure was too high, there has to be blockage some where. I'm going replace the original condenser, dryer, pull a good vacuum, and oil and recharge the system. The compressor is a remanufactured 4 seasons. My guess is that the original compressor failed, filled the condenser with crap and flushing it just won't work. Of course I'm assuming that I can put another screw in the line and get it to tighten up to the back of the compressor. I may have to replace the line and compressor if it screwed both of them up. Some times I just do stupid crap!
#11 | |
I can see using R-134 until you know it's solid and then using R-12, but it worked well enough (for me with a parallel condenser) with R-134 that I then wouldn't make the switch. So I guess all I'm saying is don't waste you're R-12 unless you're confident it won't leak. Mine vacuums OK for hours but won't hold overnight.
I personally wouldn't charge a system that wouldn't hold a vacuum overnight. If the leak cant be found easily, charge the system with nitrogen and using soapy water will locate the leak.
#13 | |
Anyone know if you can get at the evaporator core from inside the truck, or does the firewall need to come apart?
#14 |
Old member
The evaporator is on the motor side of the box. The heater core is on the inside.
#15 |
Thanks. From cursory inspection it looks like you should be able to get at it by taking the whole underhood box apart in the middle, correct?
Does anyone know? I'm just worried I don't want some shop I have little experience with pulling fenders off my truck, etc... I have to use an "unknown to me but otherwise recommended" shop because my preferred "old men that fix cars" shop doesn't have the AC equipment. Nor do I, or I'd do it myself! I could just vent all the R134 but that's probably illegal, might be bad for the ozone, and is expensive.
#16 |
The evap housing separates and the drivers side is removed. There are 8 screws plus the hardware that holds the poa and expansion valves.
#17 |
So today I started the A/C tear down. I bought a POA valve calibrated for 134a from F.A.A. benny. He was kind enough to take my call and answer a lot of questions before I started this process. I thought I would pay it forward and post pictures of the tear down and share what money I've spent rebuilding the system. I'm replacing the original condenser and main hose with part#11-7201 $220 and part#95-7215A $115; shipping costs $49 from Old Air products. I bought a reman compressor from Auto Zone for $134.99 and a new receiver dryer for $16.99.
#18 |
Pictures
#19 |
more
#20 |
My goal in posting the pictures is that you can see what screws need to be removed and just how clean the evaporator core looked from the outside.
#21 |
Now with the clamshell and evaporator removed you can see that at least half of the evaporator was covered in years of leaves and dirt. Benny has posted before that you should remove the evaporator to clean it, I heeded his advise. After removal I've used two cans of brake cleaner to flush and its still not pouring out clean. I'll post more pictures later.
#22 |
Update; pictures of Old Air Products condenser. I placed the new one on top of the original condenser so it would be easier to see size and comparison of the two.
#23 |
F.A.A Benny suggested draining the oil from the new compressor and filling with PAG 150 before installation on the truck. I'm glad I did, there was only a couple of ounces of oil and you can see that it looked nothing like the PAG oil. I added 11 ounces of PAG 150 (the blue colored oil).
#24 |
Receiver/dryer installed. Pulled a 4 hour vacuum, and 16 hours later no leaks.
#25 |
Many on this site have suggested 41 to 42 oz of 134a (80% of R12 fill). I first charged with 36 oz of 134a and pressure was too high, 60 on the low side and just over 300 on the high side. I evacuated and vacuumed the system back down. Refilled with 24 oz of 134a and pressure was better, just under 40 on the low side and ~250 on the high side. Outside temp here today was ~80 degrees with ~30% humidity; temp in the cab at the center vent just above ~40 degrees. After a lot more reading and research the pressures were probably high because I was idling in my garage and not pulling enough air across the condenser. I'm going to drive the truck some before adding any additional freon. I hope this post helps someone decide if they want to tackle this job on their own or hire an experienced tech. I hired someone to do all this fours years ago, it was half assed so I decided that I would do it myself this time. It's a lot of work and not for the timid:-)
