Old 08-09-2016, 09:59 PM   #1
reed62
reed62's Avatar
Solid Motor Mounts - Opinions, Pros and Cons
Hey all,
My 62 had a Pontiac 400 transplanted into it before I bought it and I really want to keep it. The issue is it has the clam shell style block mounts and the traditional chevy square rubber motor mounts used in the Firebird and Camaros. In order to mount it, they PO used some C-channel steel cut down to about 1.5" tall and then welded the motor mounts to it. Then they welded the C-channel to the cross member. I have tried using and modifying 73-87 C-10 perches but they will not fit inside the frame rails when mocked up. I have also looked at 67-72 perches but they sit too high and do not have the flat mounting surface that the rubber mounts need.
So that leads me to my thoughts about using solid mounts. I used them on my 1950 F-3 when I built it and didn't have any problems, but I only drove it for a few hundred miles before I sold it.
What are your thoughts on solid motor mounts? Good idea? Bad idea? Dangerous? Hard on the engine?
reed62 is offline   Reply With Quote
Old 08-09-2016, 10:17 PM   #2
padresag
Re: Solid Motor Mounts - Opinions, Pros and Cons
why does every vehicle have rubber mounts. that may tell you something
ron
padresag is offline   Reply With Quote
Old 08-09-2016, 10:20 PM   #3
reed62
reed62's Avatar
ron
True, but there are dozens of companies that offer solid motor mounts.
Old 08-09-2016, 10:37 PM   #4
padresag
what do you mean by solid motor mounts then?
ron
Old 08-09-2016, 11:05 PM   #5
reed62
reed62's Avatar
ron
So a solid motor mount has no rubber product in it. The steel clam shell that mounts to the block has a hole in the front and rear where the long threaded that normally goes through the rubber cushion which bolts to the cross member. Here is the link to a picture of what I have bolted to the block and what companies like Summit Racing sell that mount to the frame.
Solid frame mount
https://www.summitracing.com/parts/m...cPUaAgz78P8HAQ
And this is what I have bolted to my block:
http://transamcountry.com/community/...?topic=67718.0
Old 08-09-2016, 11:09 PM   #6
padresag
are you going racing?
ron
Old 08-09-2016, 11:26 PM   #7
reed62
reed62's Avatar
ron
No... but I also am trying not to have to fabricate what would amount to be a 2" spacer in order to fit the motor.
Old 08-10-2016, 01:07 AM   #8
Fatherof3
Fatherof3's Avatar
Sponsored by Loctite
Drag or show only, drag or show
65 C20 292 4spd 4:56 Eaton HO52
Fatherof3 is offline   Reply With Quote
Old 08-10-2016, 01:57 AM   #9
ryanv70c10
With solid mounts, any frame flex gets transferred to the block. These trucks flex a lot so I wouldn't do it or you might end up with a cracked block.
ryanv70c10 is offline   Reply With Quote
Old 08-10-2016, 11:26 AM   #10
andyh1956
If you do go with solid race car mounts you must tie the engine down so it can't torque flex, it WILL break SOMETHING. Been there done that
andyh1956 is offline   Reply With Quote
