08-10-2016, 07:36 AM | #1 |
72 power steering question
I'm in the process of setting my 72 up with power steering, and none of my local parts stores can order the power steering gear box.
Are there any other models or years power steering gear boxes that are a direct bolt in? Thanks. |
08-10-2016, 07:54 AM | #2 |
Re: 72 power steering question
they are direct bolt up to 87, I think the one I used was 79-86 just make sure the PS pump you use also has metric fittings early pumps and gear have SAE thread and Newer style have Metric . Do a search here all the information is here on the best way to go.
08-10-2016, 08:03 AM | #3 |
08-10-2016, 09:16 AM | #4 |
Go with a 77-80 gear box. They have a quicker (3.5 turn) ratio than the older ones yet still have the same sae fittings as the earlier pumps. That way you can get a pump and lines "for a 72" and it'll all work together.
1967 C10, LWB, 250, Powerglide, PS, PB, 3/4 STATIC DROP |
08-10-2016, 09:21 AM | #5 |
The pump I have is from a 2000 silverado. It's on the motor I'm using. I think I will need to have line made anyway.
But I do like the idea of a quicker ratio. Thanks |
08-10-2016, 09:25 AM | #6 |
It's weird they can't order a stock steering box. I ordered mine for my 72 w/ps from advanceautoparts but cancelled and just ordered from rockauto becausenitnwas a much better price
Bill 2004 Chevy Silverado Z71 Ext Cab 1500 1972 Chevy K-10 SOLD 1967 Chevelle SS |
08-10-2016, 10:41 AM | #7 | |
I might just get a junk yard box. |
08-10-2016, 10:51 AM | #8 |
Hollister Road Co.
not all C10 boxes are the same to 87. Somewhere after 76 or 77 they changed to metric. The shaft will be different
08-10-2016, 10:53 AM | #9 |
If you have to order a new box, consider a faster ratio or even a CPP500 box. I'm about to have to do this myself...
08-12-2016, 05:01 PM | #10 |
I ended up buying a used box from a 74 c20. It bolted right up no problem. I did need to trim the bumper bracket though.
Thanks for the info eveyone. |
08-12-2016, 07:28 PM | #11 |
I may have to go that route now too. In my post above, I said I had bought a re manufactured box from RockAuto (Lares 959) and now the damn thing is leaking after about a month. Right where the pitman arm attaches. It has a limited lifetime warranty, but I can already forsee the hassle of trying to return a 35 lb steering box, and then waiting months for a replacement
08-12-2016, 08:20 PM | #12 | |
I had a similar return problem that when I called and talked to a tech person and explained what was going on with the front wheel cylinders being they had a fitment problem, I sent a Email to them with an explanation and some pics with what was wrong with there W/C's they seen the problem and Credited my Card with NO PROBLEMS also told me to keep the ones they original sent (no good to me). In my opinion Rock Auto was right on the ball, never have I had any problems with any person on the other end of the phone. |
08-12-2016, 09:15 PM | #13 |
The local parts store can get it, but you may have to provide the number of the part you want. Every parts store has a website where you can enter details of the vehicle and find parts. Almost every parts store has halfwits working there that know almost less than nothing and can't do anything useful.
08-13-2016, 01:26 AM | #14 | |
I Apologize to any and everybody that this might have offended in any way, all or most of us start out somewhere by knowing or not knowing that's called LEARNING. I also might have been a little bit of a halfwit in my early days of growing up but with a little hard work I retired as a Electrical Engineer 30+ yrs under my belt. HOORAY for Halfwits!!! **I just had to get that off my mind. |
08-13-2016, 09:43 AM | #15 |
We are fortunate here in the PNW to have a local company that rebuilds steering boxes. I had great success on my 93 Jeep YJ.
Redheadsteering.com https://www.redheadsteeringgears.com...tags=1&ixwps=1 ^ appears to be what you are looking for? Hope this helps... |
08-13-2016, 10:01 AM | #16 |
All about them K’s
Red head gears have a very good reputation. That's what's going on my K/20 when I get around to it. As for the parts store gears, I've had mixed results with their rebuild quality. A couple of those units leaked almost immediately out of the box, and 1 was ok.
I know that some people in the parts store are just starting out in adult life, but we've got a local guy here who's probably in his 50s that is as useless as a splinter in your butt. He used to manage the local dollar general before autozone came to town. Now he manages the autozone. Id probably have better luck with fence posts listening to and getting what I need. In my case with the exception of Napa, the local stores are all what I'll call "retail" experts. They are just trying to move parts and don't really care if it's what you need or not. None of them seem to have any one who has much of any automotive experience. They just put stuff in the 'puter and do what it says. Our Napa is pretty good at getting exactly what you need and not taking years and multiple trips to do it.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne: 5” lift, 35’s, front dana 60 blah blah blah… http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB: 4” lift 33”s… in a million pieces http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 35x12.5x20’s |
08-14-2016, 12:36 PM | #17 |
+1 on Redhead. Their box is what is in my truck and is the about the best money I've ever spent on it. Day and night difference from my prior experience with rebuilt steering boxes.
I went through 3 parts-store rebuilt boxes on an '88 C1500. None were what I would call rebuilt, they were resealed and painted. And a waste of money and time. +1, also, on the parts store halfwits. Though I doubt the rate of halfwits in that industry is greater than the rate of halfwits in other industries. It is just relative. Someone at NASA is probably calling a co-worker a halfwit, too. |
10-14-2016, 12:57 PM | #18 |
YOU MUST BE IN THE WRONG PART OF THE COUNTRY OR YOUR LOCAL PARTS STORES ARE NOT DOING THERE JOB RIGHT. HERE IN SO CAL WE HAVE NO PROBLEMS ORDERING A STEERING GEAR BOX. Also a lot of Restoration Catalog places have re manufactured gear box's. May be your not looking hard enough?
10-14-2016, 06:15 PM | #19 | |
It's not about how smart you are (though it helps) or where you start out, it's about taking whatever job you HAVE seriously and doing it well. Now, that said, there's always an exception. But those guys tend to wind up at NAPA I think... not Schucks.
10-15-2016, 05:18 PM | #20 |
A1-Cardone part number; 27-7501. go to any parts store, they should be able to order it for you.
01-05-2019, 07:12 PM | #21 | |
